Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 05-28-2004, 11:36 PM   #1
jordandvm's Avatar
Profile:  2005 28' International CCD
1977 Argosy 22
Western , Oregon
Images: 58
A/S trailer mileage
Is there any simple (automatic) way to track of actual mileage put on an A/S trailer (other than using trip mileage on tow vehicle)? I just purchased a 22' International CCD, and would like to keep track of the mileage traveled. Are there any mileage meters one could put on the trailer wheel/axle to keep this information?
Jim & Cheryl
2005 28' CCD
1977 22' Argosy
2004 Chevy Avalanche 2500, 8.1L 4.10 rear axle
Prodigy brake controller/Equalizer hitch
Honda 3000 genset
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 05-29-2004, 05:02 AM   #2
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
You could install a "Hubometer". You see them on tractor trailer rigs. They mount across two lug nuts. You may not be able to use a hubcap on that wheel if one is installed. Do a google search for "hub odometer" or "hubometer".
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 03-20-2007, 05:41 AM   #3
Rivets?
nvestysly's Avatar
Profile:  1992 29' Excella
North , Georgia
Hubodometer?
I'm also looking for a convenient way to track trailer mileage. Hubodometers look like a good way to do this. Has anyone used a hubodometer? Any comments are appreciated.
Lucius
Lucius and Danielle AIR#25 WBCCI#16771 WDCU
'92 - 29' Excella, '96 - GMC C2500 Suburban
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 03-20-2007, 07:20 AM   #4
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Lucius
I have, but only on larger (40' semi) trailers. It shouldn't take much to install one on your trailer, just make sure you get one for the correct size tire/wheel assembly so it will be accurate.
(No Longer at Inland RV)
Old 03-20-2007, 07:31 AM   #5
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
When we first got our Airstream, we looked into a mileage recording device. We found they they were kind of expensive for what you got. We decided to go to a trailer log where we keep track of the mileage, nights spent out and where, and other maintenance items.
We don't use the TV trip odometer to record mileage. We determine the miles traveled between points using Microsoft Streets and Trips or Yahoo maps if we are online. This system has worked out well for us. We have already logged 12,000 miles and gone through one 10,000 mile maintenance session.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 03-20-2007, 07:57 AM   #6
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 12
Shortly after I bought my trailer 12 years ago I installed a Stemco Hub Odometer. It has recorded over 106,000 miles to date.
Odometers cost about $50.00 and can be mounted to an Airstream hub cap by having a center hole drilled in the cap. The hole should be done on a lathe to insure it is centered and thus the hub is balanced to the wheel.
The only short coming is when mounting a tire you have to remove the odometer to get the hub cap off the wheel. Small price to pay.
When ordering you have to give them you tire size to calibrate the unit.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 03-20-2007, 10:13 AM   #7
ScottW's Avatar
Profile:  2007 30' Classic
Hernando , Mississippi
JIM,
Ditto Moosetags. We also keep a simple log in our TV and document mileage, sites, things to see/do, maintenance etc. Works for us.
Rgds,
Scott
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 03-20-2007, 11:47 AM   #8
Rivets?
nvestysly's Avatar
North , Georgia
Stemco for $42
Stemco corporate indicated I must purchase the part through a distributor. I called the local Stemco supplier and they can get the appropriate hub odometer in less than 1 week for $42. If I decide to go this route I'll simply drill a hole in the chrome center cap. My wheels and center cap look just like yours.
Thanks for the suggestion.
Lucius
Old 03-22-2007, 06:06 PM   #9
Profile:  2001 19' Bambi
Greensburg , Pennsylvania
See the attached picture for the Abbot Hubodometer I purchased and installed for my Bambi. It has worked fine for me. Find them at: Abbott Enterprises - hubodometer. I recall it cost me $24. with $4 shipping in 2001.
Marshall Swartz
2001 19-ft Bambi
2006 Honda Ridgeline RTL
Greensburg, PA - Falmouth, MA
mswartz is offline   Reply With Quote
Old 03-22-2007, 07:04 PM   #10
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
You know, when I first started keeping track of my mileage on the Safari by keeping a log, then entering it into the computer, I though man, I'm not gonna share this one cause folks will think that I'm even more excessive compulsive that I really am, then I read this post and was pleased to find there are folks doing what I do or doing it even more accurately than I am!
Thanks all, you just validated my compulsions! Admitting it is half the road to recovery!
Old 03-22-2007, 07:23 PM   #11
RangerJay's Avatar
Profile:  2002 19' Bambi
Northwestern Ontario , Just above the big green spot
Double ditto with Moosetags.
Streets and Trips is about as pain free as you can get - we record the information on a simple spreadsheet which calculates for us:
- daily mileage
- trip mileage
- yearly mileage
- cumulative mileage
.... and also serves as a complete journal of camping days, dates, locations and associated notes.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2003 (The Buggy)
RangerJay is online now   Reply With Quote
2003 - 22' International A/S DonM For Sale & Wanted 0 04-23-2004 12:45 PM
Seekn' short gutted A/S Trailer txbeaux For Sale & Wanted 6 03-06-2004 03:25 PM
Swash Vinyl on an A/S trailer. Navigator Clearcoat, Exterior Paint & Trim 0 12-14-2003 05:25 PM
A/S Trailer in Chevy Truck TV ad vajeep Our Community 16 10-08-2003 07:38 PM
What's the purpose/function of the stainless(?) "sleeves" on the A/S trailer tongue? Dave Jenkins Our Community 5 08-20-2003 09:08 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
