Old 11-24-2012, 11:10 AM   #1
Wasilla , Alaska
'94 34' Excella Classic Limited
Im a new member and Im looking at a 1994 (built 8-31-1993) the ad says 94, 34 foot Excella Classic, Limited, not sure what the title says. Anyway, I went into town to look at this, the owner is out of town, house is up for sale too, not plugged in, no batteries so I could not try anything. About all I could do was look at the basic shape and it doesnt look bad.
Here is what I dont like. The center tire on the curb side is down to the steel belts on the outer edge, the center and the inside of the tire look fine. I cant see that it is bent, the driver side looks fine and all the other tires are good. Do you think its an alignment problem? Have done a lot of reading on this site but have not seen this one.
It is missing both corner window stone guards and on the curb the lower guard where it attaches has a repair.
Any ideas what would make the tire do that? I see the axels are rated 2800lbs. Anyone have a guess how much to replace all the axels?
They are asking $12,500.
Tom NL7TZ
ID:	173175   Click image for larger version
ID:	173177   Click image for larger version
Name:	_DS19910 (Large).JPG
ThomasRut is offline   Reply With Quote
Old 11-24-2012, 11:24 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Since the wear is only on the outside of the tire, I would say it is just an alignment problem. There are places that can bend the axle to fix it, but I am not sure who is available in Alaska. It should cost less than $500 to fix it. I would test the axles to see how much life is left in them but they should check out OK. Test procedure is simply jack up the trailer and measure how far the move down. Some people just jump on the bumper and see how well they move to absorb the load.
Old 11-24-2012, 07:12 PM   #3
Phoenix , Arizona
It is a triple axle trailer and the tires are known to "scuff" really bad when making tight turns. I'll bet that is the problem.
M2HB is offline   Reply With Quote
Old 11-26-2012, 06:27 AM   #4
1977 31' Sovereign
1989 34' Excella
The six wheelers do scuff but the wear is usually even on the front or rear tire. The picture shows it as the middle tire, that tire position does not usually scuff. It could be you have a dragging brake.
Old 11-26-2012, 02:54 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If the center tire was rotated out of another position it might explain the wear. The other reason might be axle alignment. Taking a string and stretching it across all 3 tires of the same side might tell you a story. The string should touch the side wall of all 3 tires as it is pulled tight against the front and rear tire. If both sidewalls of the center tire touch the string I would NOT suspect axle mis-alignment of the center axle.
>>>>>>>>>>>>>Action
Old 11-26-2012, 05:45 PM   #6
Wasilla , Alaska
(From the owner in an email)
“It hasn’t been used in 4 years just sitting the hot water heater and furnace wouldn't kick on and the water pump for the bathroom and shower didn't come on it all worked 4 years ago”
I will be going back in to town this weekend to look at it again, the owner will be there this time so he can show me around, plug it in and I can ask questions.
We can’t check the water system because it is 0 outside but will check what I can.
I will ask about if the tire was moved and pull a string and look at that.
I should know a lot more in a week or so.
Tom, NL7TZ
Old 11-26-2012, 06:53 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Good luck.
>>>>>>>>Action
Old 12-11-2012, 08:17 AM   #8
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Thomas,
What did you decide about this trailer?
Steve
Steve Bryant is offline   Reply With Quote
Old 12-11-2012, 08:32 AM   #9
upstateart's Avatar
1994 34' Excella
newark , New York
Could it be that they ' rotated' the tires and the middle tire received the wear in a different placement ?
Front or rear ....
Just a thought....
upstateart is offline   Reply With Quote
Old 12-12-2012, 10:42 AM   #10
Wasilla , Alaska
Nothing yet, the last email I received said he was weathered in at work and it would be two weeks before he can get back to town. That should be this week sometime; I will go in and meet with him and report back.
The only thing about the tires is there is only one tire that and any were on it.
We will find out more soon.
Tom NL7TZ
Old 12-12-2012, 10:50 AM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Vaughan
Old 12-14-2012, 12:15 PM   #12
Wasilla , Alaska
As it turns out we decided to pass on this Airstream at this time, we will keep looking and when we are in the lower 48 I think we can do better finding one.
Thanks for all your help, I will be around here looking and learning all I can.
Tom NL7TZ
Old 12-14-2012, 09:18 PM   #13
1991 34' Limited
Wichita , Kansas
Tom,
You're probably smart to keep on looking. There's a lot of learning to be done before buying an Airstream or any older travel trailer for that matter. Keep learning and keep looking!
All my best,
Steve
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
bake315's 1994 34' Limited :: 1994 Airstream Classic Limited bake315 Airstream Registry Discussions 1 08-31-2011 03:01 PM
Esmerelda :: 1992 Excella Classic LawChick Airstream Registry Discussions 0 08-19-2011 08:32 AM
2011 Classic Limited 30 :: 2011 Airstream Classic Limited Wyndridge2 Airstream Registry Discussions 0 08-19-2011 08:32 AM
Classic -vs- Classic Limited 10Smiles Dollars & Cents 11 06-22-2011 08:33 PM
