Old 02-21-2010, 07:57 AM   #1
Elf1's Avatar
1990 34' Limited
Proud to be , an American
'90 Limited 34' (Axle and shock replacement) URGENT HELP PLEASE
Hello All-
Many thanks first off for any assistance that you might be able to lend.......
Andy....are you our there ???
I have a 1990 34' Limited, which we are doing a complete overhaul on inside / outside.
We are replacing the brakes/ shocks / axles. Hence my questions here.
1. We are replacing the full brake ( including the backing plate) Are the self adjusting units any "better" than the non-self adjusting units??
2. What size Shock is recommended in this unit ? a source to obtain them??
3. Looking at Dexter # 11 Axles (Heavy Duty, fully enclosed ) We travel 25k + a year ...think AK WY MT off the beaten path ..... Dexter fo some reason does not recommend their #11 dura torque in a tri- axle, but they worked VERY well on my dual axle 28"...
Without saying the bearings will be cleaned, repacked and a new seal applied- any thoughts on replacing the bearings on a PM basis? This unit has been sitting in the FL heat for some time, with ZERP PM on these parts.
Any and all comments, suggestions are more than welcomed!!
Safe Travels to All
Elf1 is offline   Reply With Quote
Old 02-21-2010, 08:11 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
They aren't any better, but the self-adjusting part is more convenient.
The shocks are Airstream specific, and you can get them at any Airstream dealer. Bates and Saunders in Florida, or Out of Doors Mart come to mind.
Even though the 34 weighs more than the 28, the weight per axle is less.
Replacement is generally not indicated unless the bearings show damage. If they do, be sure to replace the races as well.
Old 02-21-2010, 08:20 AM   #3
Elf1's Avatar
1990 34' Limited
Terry,
Many thanks for the "rapid reply" ....Any suggestions on the Axle of choice for a 34'??
It pains me to think that there is not a HD self lube axle out there for this application -
Many Thanks-
1990, brakes, replace, shocks, axle
Axle specs for my '65 Caravel Sheridan 1965 Caravel 6 04-25-2014 08:55 PM
Replaced axle '61 Tradewind 61 Streamy Axles 8 10-19-2011 10:03 AM
My very own axle thread! Top Axles 118 10-05-2011 04:08 PM
