Old 07-24-2013, 09:46 PM   #1
thomdial's Avatar
1979 23' Safari
, Ohio
'79 low profile axle
My 79 Safari has low profile axles. It seems like most of the axles I've seen on the forums have been the high profile type. I'm really looking for something with the least amount of necessary modifications if you get my drift. I'm attaching a photo of my low profile axle bracket. Any experience with this?
thomdial is offline   Reply With Quote
Old 07-24-2013, 09:57 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Thom,
I have the low profile axles on my 1979 Safari also. I have new axles but not installed them as yet. I was told that it is necessary to redrill one hole on each bracket, but not confirmed that. I was also told that there is no redrilling required on the high profile brackets.
I ordered the axles through Colin Hyde by Uwe at Area 63 in Orange, CA.
Hope this helps.
Bill
Just my personal opinion
Old 07-24-2013, 10:14 PM   #3
Why do you want low profile mounting brackets when most all tow vehicles today are high profile?
The higher profile makes rigging much easier.
Old 07-24-2013, 10:15 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
By "low profile" do you mean worn out such that the arm from the axle to the hub points above the horizontal?
Except for the extra flange wrapped around the back of the bracket, it doesn't look that different from my new ones shown below. Am I missing something?
— David
Old 07-25-2013, 09:12 AM   #5
thomdial's Avatar
1979 23' Safari
, Ohio
Hey Bill,
I would be real interested in seeing what your axle brackets look like. So you are saying that they are the high profile?
Thom
Old 07-25-2013, 09:16 AM   #6
thomdial's Avatar
1979 23' Safari
, Ohio
Andy,
I'm not sure what I'm gonna end up with at this point, but to answer your question, I had not planned on changing the ride height and profile on my trailer.
Thom
Old 07-25-2013, 09:19 AM   #7
thomdial's Avatar
1979 23' Safari
, Ohio
DKB SATX,
The major difference that I see in our brackets is your axle sits about an inch below the body pan and frame. My axles sit flush with the frame and belly pan.
Thom
Old 07-25-2013, 09:30 AM   #8
DKB_SATX's Avatar
1976 Argosy 28
DKB SATX,
Thom
I guess an inch is a big deal where center-of-gravity and hitch height are concerned. I was looking more at the shape of the brackets themselves than the final position of the axle tube, but I see what you mean now.
The change on mine was from old axles to new and it raised the trailer about 1.5" which didn't seem like much, but it gives me more clearance to level in sloped campsites, and gets me a little more drop from the dump valve to the dump station.
— David
Old 07-25-2013, 09:35 AM   #9
thomdial's Avatar
1979 23' Safari
, Ohio
Thanks for the info. I may eventually go the same route.
thom
Old 07-25-2013, 09:55 AM   #10
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Thom,
I will post a picture tonight when I return home.
Regarding Andy's post, I went with the low profile bracket and 22.5 degree down angle since I tow with a 1977 Lincoln Continental and do not want a higher trailer. In addition, my wife is in a wheelchair and the lower height of an Airstream makes her entry and exit much easier.
Since I have a vintage trailer, the dump valves do not hang down like the new trailers.
Bill
Hey Bill,
Thom
Old 07-25-2013, 11:57 AM   #11
thomdial's Avatar
1979 23' Safari
, Ohio
Bill,
I would love to see a picture of those axles. They are probably close to what I will be getting from Colin as well. Are you putting them on yourself?
Thom
Old 07-25-2013, 07:35 PM   #12
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Thom,
Here is a picture of the existing axle and two pictures of the new axles.
Bill
ID:	191737   Click image for larger version
Name:	2013-07-25 18.27.49.jpg
Name:	2013-07-25 18.28.05.jpg
Old 07-25-2013, 09:01 PM   #13
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Thom,
I will be installing them myself, with help.
Bill
Old 07-25-2013, 09:02 PM   #14
Originally Posted by wkerfoot View Post
Thom,
Bill
The shock brackets don't have a shock stud in them.
Are you having to install that stud?
2003 Airstream Land Yacht 30' J Low Profile Motorhome With Extras eBay Watch Airstreams on eBay 0 12-03-2011 11:00 AM
2003 Airstream Land Yacht 30' J Low Profile Motorhome With Extras eBay Watch Airstreams on eBay 0 10-15-2011 09:30 AM
If you were going to install a new low profile AC... scarylarry Furnaces, Heaters, Fireplaces & Air Conditioning 10 07-08-2011 06:51 PM
Best low profile roof top A/C unit??? hotstuff Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-29-2011 06:08 PM
