Old 10-12-2015, 02:15 PM   #1
Sgtfun's Avatar
1978 25' Tradewind
Carlsbad , California
'78 Tradewinds Axel replacement
Hello!
I have a 78 Tradewinds with original axels and unknown brake age. While coming back from Yosemite last week I had a brake spring fail, which I tried to fix this weekend. After taking it apart, it occurred to me that Id need to go through all the brakes and maybe it's time to "just do it" and do a complete replacement of the axels & brakes.
It seems that a break/bearing job is going to cost me about $400 and $1400 if I buy complete replacement axels and do the work myself. Instillation, it seems, will take an equivalent amount of time either way.
Any advice from folks who have been in the same situation? Other than cost, it there a reason not to go all the way?
Thanks, Erik
Sgtfun is offline   Reply With Quote
Old 10-12-2015, 03:25 PM   #2
1976 31' Sovereign
Oswego , Illinois
Go with new complete axles with everything installed, less expense long run. Older axles shot any way, and if you are handy easy to change.
Replacement Parts 1960 Tradewinds djweir 1959-69 Tradewind 10 08-05-2014 09:42 AM
Axel ratio- need to discuss my rear end.... crazylev Tow Vehicles 21 12-30-2005 10:13 AM
controller for tag axel brake lorcaweb Classic Motorhomes 5 07-01-2005 09:32 AM
Tag Axel Brake Voltage / Amperage 87MH Mechanics Corner - Engines, Transmission & More... 1 11-11-2003 09:25 AM
