Old 12-20-2008, 02:07 PM   #1
Lothlorian's Avatar
Loganville , Georgia
'73 Overlander axle will not come off
I have it up and off the ground (safety first) and I have all the bolts off the front axel. I took the tires off. I took off the shock and the two bolts holding the axel on to the fram and it won't drop. I am trying to do this with a floor jack but when I release the jack the jack drops but the axel stays put. I have been under the trailer and looked all around and cannot see anything holding the axel up. Is it rusted on? It won't budge.
Lothlorian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 12-20-2008, 02:23 PM   #2
richinny's Avatar
2011 34' Classic
i think there are two bolts on each side.
Ricky
Old 12-20-2008, 02:29 PM   #3
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Lothlorian
Put the jack up and step on the hub. it will come. Just a little tight.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-20-2008, 02:32 PM   #4
Lothlorian's Avatar
correct and I got all the bolts off on both sides. I am going to go back out and take a look again. Yep, all the bolts are off.
Lothlorian
Brian & Adrienne
Old 12-20-2008, 02:33 PM   #5
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Mine was also very tightly fit, had to pry/pull/push a little at a time from side to side.
tphan is offline   Reply With Quote
Old 12-20-2008, 04:40 PM   #6
Lothlorian's Avatar
tphan:
Thanks for the advice. I pounced on it with my weight and she came loose. It is on the ground making a nice Christmas decoration in the driveway.
Lothlorian
Brian & Adrienne
Old 12-20-2008, 05:17 PM   #7
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Be safe put that jack in the center of the axle tube. No pressure, just very close. Sledge hammer on the drum, if you are savin the drum ,lay a piece of 2x4 on the drum. They can get a little cantankerus. I had to persuade mine on the 77 to drop out.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 12-20-2008, 11:25 PM   #8
1972 25' Tradewind
Madison , Wisconsin
Bigger Hammer!
I had to beat the plate with a hand held air hammer and plenty of break free.
Smokin Camel is offline   Reply With Quote
Old 12-21-2008, 08:27 AM   #9
axle removal.
Sometimes a little corrosion between the axle mounting bracket and the axle mounting plate takes place.
That small amount of rust amazingly can hold the axle in place, which then takes more effort for removal.
If you know the axles will be changed, spray that junction several times over several days with WD-40.
That usually does the trick.
If not, then you can also wedge the axle loose with a crow bar.
BE CAREFUL.
Old 12-21-2008, 02:51 PM   #10
Lothlorian's Avatar
Just posting some pics of the front axel removed.
Lothlorian
ID:	72772   Click image for larger version
ID:	72774   Click image for larger version
Brian & Adrienne
Old 12-22-2008, 12:11 PM   #11
funkill's Avatar
reno , NV
Images: 27
Looks like we were doing the same thing this weekend.... replaced my 73's axles too. Had the same issue getting the axles *dislodged* - but beat on my spindles with a sledgehammer. Worked - but not nearly as refined as other methods.
funkill is offline   Reply With Quote
Old 12-22-2008, 01:49 PM   #12
vhord's Avatar
Images: 96
For what is worth, mine seemed to go back in place easier than they came out, but then I had three buddies helping me.
vhord is offline   Reply With Quote
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 02:25 PM
1956 Airstream Overlander 26 feet Twin Axle Immaculate eBay Watch Airstreams on eBay 0 08-06-2011 04:40 PM
