Old 04-04-2016, 11:55 AM   #1
1972 31' Sovereign
Sanford , North Carolina
'71 Sovereign 31'
Just bought this gutted Airstream. Changed the tires to new tires and rims. I was looking at the axles and they look pretty bad. Probably original. Do I just bite the bullet and replace them?
btyler48 is offline   Reply With Quote
Old 04-19-2016, 07:41 PM   #2
1977 31' Sovereign
2005 30' Safari
North Port , Florida
Yes. You could use them as is but will be beating up your trailer which will cause more problems down the road
cliffcharb is offline   Reply With Quote
Old 04-23-2016, 12:00 AM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Depends on what you mean by "...they look pretty bad."
If they're the original axles, they probably are bad. The most recommended way to tell is to see if they drop when the trailer is jacked up.
Old 04-25-2016, 11:52 AM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The only alternative is to do nothing as there isn't a repair. As long as it isn't being towed for any distance, doing nothing does not create potential damage to the coach.
>>>>>>>>>Action
sovereign
1974 Sovereign Land Yacht :: 1974 Airstream Sovereign Land Yacht MyTwinkie Airstream Registry Discussions 0 01-13-2012 08:51 AM
Sovereign :: 1987 Airstream Sovereign tinkerinwv Airstream Registry Discussions 0 11-28-2011 12:12 PM
Sovereign :: 1960 Airstream Sovereign truckasaurus Airstream Registry Discussions 0 11-20-2011 11:53 AM
1973 Silver Sovereign 31! AIRSTREAM. LOW RESERVE S1973 Silver Sovereign 31! AIRSTREAM eBay Watch Airstreams on eBay 0 09-22-2011 11:20 AM
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 08:31 AM
