Old 06-14-2014, 03:38 PM   #15
Baltimore , Maryland
Originally Posted by RM66caravel View Post
(backing plate has 4 bolts each)
Cliff
Not his, his 12" brakes, he has 5 bolts. Your 10" brakes has 4.
Old 06-14-2014, 04:31 PM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
'67 Safari Dexter axle installation HELP!
Why expand the slots ?
Are the replacement axles thicker where they pass through the frame on this year trailer?
It seems to me that if the axle fits tight in the slot, it is going to be lined up as well as the old axles were and the holes could simply be drilled through either the brackets or the frame.
Old 06-14-2014, 04:48 PM   #17
Totoro's Avatar
Huntington , West Virginia
Yes, what J Morgan said.
Totoro is offline   Reply With Quote
Old 06-14-2014, 04:51 PM   #18
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Thanks frank I had hoped that you were reading and would add the missing bits!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 06-14-2014, 05:13 PM   #19
1976 Argosy 26
Houston , Texas
I think its obvious the axle plate holes are no where near the frame holes.
You should be able to line up the back hole, slightly open the axle tube notch and drill a new hole for the front bolt. I wouldn't drill 4 new holes either, maybe it's the wrong plate. I would call Andy to discuss.
wzelkins is offline   Reply With Quote
Old 06-14-2014, 05:24 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you can get the square tube of the axles into the notch in the frame without modifying the notch. It would be best. Then mark and drill the holes.
Old 06-14-2014, 05:39 PM   #21
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
As far as alignment, to get the axle mounted in the right place, I would make sure the new holes that you drill are the same distance from the old holes on both sides. I would think that that should take care of that.
You might want to get an alignment when you are finished. I certainly would.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 06-14-2014, 05:55 PM   #22
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I don't know, when I took my axles out they were tight in the frame, when I put my new axles in they fit tight in the notches. The axle placement mattered on the holes not at all.
***note, I raised my trailer 3", but the procedure is the same. ***
Old 06-14-2014, 06:30 PM   #23
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Now that I think about it, when I replaced the axle on the '65 Caravel the holes were very different from the original, much like yours. The Caravel is a Jackson Center trailer. The replacements on the '83 Excella were exactly the same.
The new axles for the Excella were way out of alignment. Inland RV, wher I bought the axles, was told by the manufacturer that they were aligned at the factory. I paid for a proper alignment. Andy at Inland RV went to bat for me and got the alignment cost refunded to me by the axle manufacturer.
Have yours checked. Cheaper than a new set of tires.
Old 06-14-2014, 10:20 PM   #24
KennewickMan's Avatar
1967 22' Safari
Kennewick , Washington
Lining up the original bolt holes was the trick. We jacked the axle into place tight against the upper frame and marked all the new holes on the mounting plate. Then made up a template using original holes, made up 3 new pilot holes, drilled with step bit. Then moved template to other side and drilled those pilots. Poof, axle magic. And yes, I did put the shock on backwards the first time. Click image for larger version
Name:	ImageUploadedByAirstream Forums1402805694.753346.jpg
ID:	214233Click image for larger version
Name:	ImageUploadedByAirstream Forums1402805727.598582.jpg
ID:	214234Click image for larger version
Name:	ImageUploadedByAirstream Forums1402805770.436944.jpg
ID:	214235Click image for larger version
Name:	ImageUploadedByAirstream Forums1402805799.830733.jpg
ID:	214236Click image for larger version
Name:	ImageUploadedByAirstream Forums1402805960.764800.jpg
KennewickMan is offline   Reply With Quote
Old 06-15-2014, 03:04 AM   #25
1966 17' Caravel
Awesome job I like how it turned out! Keep up the good work but I am curious why no frame prep for the exposed area?
Jus asking
Cliff
Old 06-15-2014, 05:06 AM   #26
What is so hard about drilling a hole? I see this over and over again. It is almost as pervasive as bellypanitis.
On Monday the 107th axle to hit my shop over the past 5 years is going to be installed. I guess I have done so many now that I do not even blink an eye at drilling a hole. It is 1962 so I already know all the holes are going to miss the original ones. On each set of holes, one will be half covered by the new mounting bracket. No big deal, just drill it out. Being a 62 single axle the new axle will be a wider axle tube and it will not fit into the receiver slot and I will just cut it out. No big deal, that is what a cut off wheel was developed for.
I saw where it was said the slot should align the axle… do not count on that. Use a tape measure and make sure it is aligned. Just a little bit out can cause the wheel to drag ever so slightly. This will cause frequent blow outs on the same tire. Any of you blowing out the same tire? There is your reason why.
Old 06-15-2014, 07:04 AM   #27
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It does seem that there is some apprehension about drilling holes that "are not supposed to be there", many, many years ago I was subject to this aversion to one degree or another, not so much now.
Old 06-15-2014, 04:35 PM   #28
1967 22' Safari
Jus asking
Cliff
Ignorance, inadequate research, lack of instructions supplied with the axle....I have more excuses if you need 'em!
New Dexter Axle Installation Questions 100ProofDera Axles 8 03-12-2014 05:40 PM
Help: I need a Dexter axle part number..... raincrow Axles 14 10-22-2013 07:25 PM
Dexter axle installation Inland RV Center, In Axles 22 09-20-2013 04:27 PM
Dexter Axle Installation Started! Streamin 65 Axles 17 06-07-2006 04:02 PM
