Old 06-17-2015, 01:17 PM   #1
Savannah , Georgia
66 Overlander question
I am planning a shell off restoration. I would like to expedite this as much as possible meaning that I would like to have new axles on hand and ready to install as soon as possible. So my questions are, Who should I contact? What info do I need to have when I make the call? I would also appreciate any pointers.
Glt12 is offline   Reply With Quote
Old 06-17-2015, 02:21 PM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Axles
Model and Vin number from the plate to the right of your entry door. Vin # will start with a "O" or a "I" . Then there should be an ID plate on the axles as to weight rating and other info that you will need to provide. InlandRv. com has information on their site to help you determine what axles you need to order. Other vendors and resto shops also can get axles for you. Use the search button on the tool bar above with key words like axle replacement to read up on how it's done and who others have ordered axles from. Colin Hyde on these Forums is able to order thru his shop too! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 3 08-20-2009 10:30 PM
Price Question from a Newbie *1969 Overlander* lubbockgolf Trailer Values 3 04-24-2007 09:05 PM
1972 Overlander Frame Question Derek D Repairing/Replacing Floor &/or Frame 15 03-07-2007 06:19 PM
quick question 1967 Overlander ren walker Our Community 9 01-09-2007 10:10 AM
Help - '74 Overlander layout question Fargo 1974 Overlander 2 05-24-2005 09:44 PM
