Old 12-13-2009, 10:38 AM   #1
1965 20' Globetrotter
Bromsgrove , Worcestershire
'65 Globetrotter axle
My newly aquired '65 GT should arrive in England towards the end of December and I need to get the ball rolling with the modifications.
My plan is to fit a new torsion axle with surge brakes and a new hitch.
I know that the weight of the GT is around 2980 lbs, but I have no idea what the Airstream designers expected the total payload to be, I also know that fitting an over rated axle can cause structural problems.
So I could use some guidance selecting the correct axle weight capacity.
Can anyone assist?
Chiefy is offline   Reply With Quote
Old 12-13-2009, 11:56 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
It doesn`t take to long to add up to 1000 # of must have stuff in a trailer,don`t think I would go with less than 4,000# axle. Dave
easyride is offline   Reply With Quote
Old 12-13-2009, 11:59 AM   #3
Can anyone assist?
I will look up the axle specs for your 1965 20 foot Airstream, and post it for you tomorrow.
Old 12-13-2009, 01:01 PM   #4
Appreciate your help Andy
Old 12-15-2009, 12:55 PM   #5
Your 1965 20 foot Airstream trailer, was originally equipped with a 4000 pound axle, with 12 inch brakes.
You can upgrade it to 4500 pounds, but no more than that, or stay with the 4000 pounds.
Also, do not down grade the brakes to 10 inch. Stay with the 12 inch brakes, to assure maximum braking power for your trailer.
Old 12-15-2009, 12:59 PM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Yeah, but....
He's talking surge brakes. Does 10" or 12" matter any more? Surge brakes are moving pretty far off the electric brake map.
Who is making surge brakes work?
5 meter Langford Nahanni
Old 12-15-2009, 01:03 PM   #7
Originally Posted by CanoeStream View Post
Yeah, but....
I have no idea who can supply the "surge brakes".
Old 12-15-2009, 03:24 PM   #8
In europe most folks run surge brakes, that's how it is.
Alko who make around 80% of european Travel Trailer axles and frames will make axles to suit specific special applications including matching brakes and hubs to fit original rims.
The difficult bit will be cutting off the old Marvel hitch and fitting one that will operate the brakes, it can be done. loads of Airstreams that make it over here get converted.
I'm looking at an overhaul that will last for at least the next 30 or so years, but I have to keep an open mind, if I need to sell the GT at some time, it will be easier if it's rigged for normal european use.
Thanks for the info Andy the spread between 4000 and 4500lbs will span the conversion to axles with standard metric kg ratings.
Old 12-15-2009, 03:59 PM   #9
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have surge brakes on my tandem axle boat trailer. They work Ok but properly adjusted electrics with a good controller are far superior.
Old 12-15-2009, 04:00 PM   #10
WK57ABF's Avatar
2007 25' Classic
kendal , cumbria, UK
Chiefy:
Surge Brakes - All of the conversions to UK surge brakes on Airstreams that I have seen have looked a real mess. Bits cut off the "A" frame and ugly plates welded on to accept the coupler. In my opinion, even the dealer conversions look dreadful.
Pleased we kept the original brakes on our trailer and they are legal in the UK.
John in the UK
WK57ABF is offline   Reply With Quote
Old 12-15-2009, 06:36 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
How can you back up-hill with surge brakes?
Why not just stick with electric brakes and a good controller. Simple to install and no modification to your trailer?
Old 12-16-2009, 11:33 PM   #12
Andy & Easyride: Thanks for your help with this, it's appreciated.
WK57ABF: I'll be in contact through the UK site.
Jim Foster:
No mods to the trailer, thats great, but now I have to install a brake controller into my vehicle. OK in the USA where EBC's are easy to get and folks are used to installing them, not so good in europe where EBC's are more of a novelty than everyday use.
Also, do you really think that all European trailer owners never reverse up a hill? LOL
Old 12-17-2009, 05:18 AM   #13
Jim Foster:
Electric brake controllers today, are far removed from the past.
No connections to the hydraulic system is necessary.
The activation of the controller is done by the brake light switch. The quantity of braking is done by adjustment of the controller. The installation is a simple wiring hookup.
Old 12-17-2009, 10:23 AM   #14
BWH-Utah's Avatar
1965 22' Safari
Salt Lake City , Utah
Surge Brakes and backing-up, up a hill. Years ago, I had this problem with a Uhaul rental trailer. I got into a "spot" before I realized this was a problem. The solution I came up with was to jam a scrap of wood (2 by 4 or something) into the surge brake units sliding mechanism (on the tongue of the trailer) to hold it "open". Just remember to pull the wood block back out after you get out of the predicament.
BWH
P.S. electric brakes and the new electric brake controller units are the way to go.
BWH-Utah is offline   Reply With Quote
i want to make a dual axle globetrotter. greenrig Axles 28 01-21-2009 05:18 PM
New Henschen axle installed on the 1964 Globetrotter! GlobeTrottin 1960 - 1964 Globetrotter 18 06-01-2008 08:21 PM
21' Globetrotter axle rating Aerowood Axles 5 05-31-2007 04:58 PM
New axle, wheels, brakes, etc for '65 Globetrotter grnthumbguy Axles 15 04-29-2006 12:09 AM
Need Axle Information for '62 19' Globetrotter jlester Axles 4 04-24-2006 09:11 AM
