Old 01-28-2009, 01:30 PM   #1
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
'56 Safari Bearing Seals Needed
Anyone know of a source for 2 replacement seals? The info on the 2 original seals say: Trostel and #300-156-6F and it is a felt style seal. Thanks!
1956Safari is offline   Reply With Quote
Old 01-28-2009, 01:41 PM   #2
Airstream has not had that seal for many years.
A good replacement is National # 290944.
The O. D. is 3.002, it's 3/8 inches thick and the ID is 1.875 inches.
Old 01-28-2009, 01:49 PM   #3
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Thanks Andy! Where can I purchase those Nationals?
Old 01-28-2009, 02:49 PM   #4
I have no idea.
We have not had them for years, and neither has Airstream.
You might try seal and bearing distributors, in your part of the country.
Sorry, I could not be of more help.
Old 01-28-2009, 08:03 PM   #5
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Does this mean new axles? Jeeeeeezzz Louise, they are only 52 years old.
Old 01-28-2009, 08:23 PM   #6
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Look for a Redneck Trailer Supply house in your area. Look for
www.redneck-trailer.com There are locations across the US.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 01-29-2009, 07:27 AM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Your 52 year old axles are likely good. The 52 year old leaf springs may need some replacemenr.
There is a Redneck in Albany. However you might want to use the phone and not the road. That white stuff is kinda prevelant.
>>>>>>>>>>>>Action
Old 01-29-2009, 07:43 AM   #8
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Napa
Go to a NAPA auto parts they will find the seal for you. National Seals
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-29-2009, 11:35 AM   #9
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
NAPA's cross reference for that seal is # 18808
WBCCI 17109
Old 01-30-2009, 01:32 PM   #10
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
I also found out that the Trostel seal is on a 1964 Globetrotter I am working on. The NAPA seal is 18808 is only 1/4" in width.
WBCCI 17109
Old 01-31-2009, 08:37 AM   #11
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Its strange, the NAPA # 18808 seal does not match up.
Old 02-01-2009, 06:25 PM   #12
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
I WAS WRONG. I have a B-324-16-6 Trostel bearing seal on my 1964 Globetrotter. Cross referenced it is a National Oil Seal # 22550. Best of luck to all looking for seals.
WBCCI 17109
Old 05-22-2009, 01:26 PM   #13
Sacramento , California
I just saw that Trostel on our parts counter.
I measured 1.50 ID x 3.00 OD x .37 high
Try Chicago Rawhide seal # 15241
Metal body with rubber lip seal. Type/Style CRSA1
Have a good day!
francorios is offline   Reply With Quote
Old 05-22-2009, 01:58 PM   #14
Images: 59
francorios,
Welcome to the airforums! Many first posts are a litany of questions, problems, and pleas for help.
Your's is the exact opposite. Kudos.
markdoane is online now   Reply With Quote
axle, bearing seals
1968 Caravel bearing seals coopermr Wheels, Hubs & Bearings 10 08-22-2011 11:14 AM
16' CCD Wheel Bearing & Seals Part Numbers RDM16CCD 2005 and newer - Bambi all models 0 05-21-2009 04:37 PM
'69 GT Bearing Seals dbaur Axles 4 06-10-2006 12:00 PM
Elk needs bearing seals Elk Member Introductions 1 04-26-2006 08:46 AM
Wheel Bearing seals!!! niftypkg Axles 1 07-30-2002 03:35 PM
