Old 06-04-2009, 07:45 AM   #1
53 Clipper Owner
1953 17' Clipper
Finksburg , Maryland
Images: 8
Send a message via Yahoo to tlaudeman
'53 17' Clipper Axle Seals needed
I would like to replace the axel seals on my 1953 17' Clipper. The current seals are marked as "allis 5013, 29772". I've been told that these are no longer available and that the best thing to do is replace the axel. I have a hard time parting with the $1400 plus labor that would take. Does anyone know of a source for these seals or a replacement seal that will work on these axels?
Todd
tlaudeman is offline   Reply With Quote
Old 06-04-2009, 07:52 AM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Go online a locate a "Bearing" dealer. Suggest Purvis Bearing Service.
Also, you can take it to a first rate auto parts place and they can find them.
Do not give up....they can be found.
kennethowens is offline   Reply With Quote
Old 06-04-2009, 07:59 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
do some checking
I found all my obsolete bearings, or appropriate substitutes, at a bearing supply house. Just took the old one in there and researched it out...always found something. The bearing dealer I used was in San Antonio, TX.
Old 06-04-2009, 03:35 PM   #4
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
See if you have a "Bearing Distributors" near you they have about anything you need. Try checking for a BDI also. same company I think they have become BDI (Bearing Distributors Incorporated).
Annette
bullydogsmom is offline   Reply With Quote
Old 04-26-2011, 05:55 PM   #5
1984 27' Sovereign
seattle , Washington
did you ever find it
i have been looking for the same seals for a different app with on luck did you ever find them would apperciate any info thanks
biggen is offline   Reply With Quote
Old 04-27-2011, 06:14 AM   #6
53 Clipper Owner
1953 17' Clipper
Images: 8
I looked in all the places everyone suggested and could not find an exact match. I ended up taking the trailer to a local garage in 2009 that either rebuilt the ones I had or found them a replacement. I do not know where they got them, but I have been successfully using the trailer ever since.
Todd Laudeman
Finksburg, MD
443-605-2002
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Seals For Wheel Bearings ~ 1958 Pacer Ariz-Pacer Wheels, Hubs & Bearings 9 03-22-2011 10:50 PM
