Old 05-19-2009, 12:12 PM   #1
Lake Orion , Michigan
3 inch list
Hello -I can't fiqure out how to post new thread---so can tha axles on a 1974 Overlander wear differently from side to side...the AS I'm considering has a 3 inch list to starboard....Thanks --Bud-- in Michigan
budal is offline   Reply With Quote
Old 05-19-2009, 12:22 PM   #2
Hi Bud.
Three things can cause a listing to one side.
1. Wrong size tires on one side.
2. Bad axles, especially on one side.
3. Numerous bent or damaged outriggers.
Or a combination of those three.
The best way to check the axles, is to look at the position of the torsion arms, on both sides.
If it's strickly an axle problem, the low side should show the torsion arms, as they go rearward, going up hill.
If that's the case, the axles are shot and must be replaced if your going to travel with the trailer.
Bent outriggers on the low side, should also show some odd wrinkes in the aluminun side sheet.
Old 05-19-2009, 12:26 PM   #3
Thanks Andy -your priceless!!!!
Bud
18 inch vent cover for Avion? Used? MonkeyMudd Roof Vents, Skylights & Fans 8 01-29-2009 11:39 AM
Offset for 16 inch rims Cos Wheels, Hubs & Bearings 6 07-30-2008 11:25 AM
Looking For 4 15 Inch Alcoa Mags... Gael79 Wheels, Hubs & Bearings 7 05-16-2008 04:55 PM
10 or 12 Inch Brakes??? Sundance Brakes & Brake Controllers 8 07-10-2007 05:04 PM
