Old 05-30-2015, 12:44 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
1990s Dura Torque Axles
Hi,
I have a new to me 93 34 footer triple axle which means the axles are 23 years old. For now they "look" ok. The trailer sits high and there is plenty of tire showing between the rims and the wheel wells. I only have made one short tow. so I am not aware of any axle problems. I know from experience 70s Henshens were prone to the rubber rods hardening. How may owners of 90s Airstreams still have the original axles, or found it necessary to replace them?
Marshall
Old 05-30-2015, 10:32 PM   #2
wayne.yl's Avatar
1977 31' Sovereign
1992 34' Excella
Salem , Oregon
I too have a triple axle AS, it's a 1992. However I fear the axles our worn out on my trailer.
My reasons for thinking this are:
She sets pretty low and the arms no longer have a down angle.
When pulling over an uneven surface,
the axles should flex up and down thus keeping the tires in contact with the ground, however my axles have seemingly lost their flex. On uneven surfaces the tires are not all in contact with the pavement.
I'm planning on replacing the axles this summer if I can find a dealer who supplies them.
"The significant problems we face cannot be solved at the same level
of thinking that created them." -Albert Einstein
wayne.yl is offline   Reply With Quote
Old 05-31-2015, 10:20 AM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
I am going to take my 34 to the International which is only a couple of hundred miles away, and will be paying close attention to the axles performance. Last time I checked with Inland RV the axles were on sale at a pretty good price.
The key questions seem to be 1. Were 90s axles built any better than their predecessors? and 2. Will having 3 axles instead of 2 in any way help the axles last longer? (which I have absolutely no factual reason to assume)
Old 06-03-2015, 01:29 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
1) NO
2) May be. Triples support less weight per axle than a single. However it isn't weight that shortens axle life.
With that said the best thing for a torsion axle is to be used in towing. Keeping the rubber rods inside the axle assembly in use goes to extendig life. Overloading will damage them and I would guess you are not over loaded. Again it is easier to over load a single axle trailer than it is to overload a triple.
>>>>>>>>>>>>>Action
Old 06-07-2015, 12:24 AM   #5
1993 34' Excella
Two Rivers , Alaska
I have a '93 34' and am wondering the same thing. After a 24 mi trip to town, I discovered some open drawers and cabinets. I think I got the message. Good luck with yours.
stevkenn is offline   Reply With Quote
Old 06-07-2015, 05:31 AM   #6
sandlapper's Avatar
1993 34' Excella
York , South Carolina
I also have a '93 34' with original axles. I am satisfied they are in good condition based on the amount of tire showing, the ride, and the angle of the arms. I also believe extended axle life is another benefit of the triples.
As for how many drawers come open during a trip, much of that depends on actual road conditions...generally very poor, and condition of the 23 year old latches.....generally very worn.
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 06-07-2015, 06:17 AM   #7
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
We have a 1997 34'. I found it necessary to replace my axles. That said, my trailer also sat for several years of its life, and this is what I believe caused the premature hardening of the suspension. Had the trailer been out on the road regularly, I am sure I would still be running no the originals.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 06-07-2015, 07:17 AM   #8
1994 34' Excella
Warren , Manitoba
Replaced mine last fall after having the front wheel on the curb side snap off when backing into a campsite. I can't believe the difference with the new axles. No drawers or doors open after travelling on the same roads as before. Trailer sits about 3" higher now.
Got #4000 axles from Inland RV. Best money I have spent on the trailer!! Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 06-07-2015, 07:36 AM   #9
Boerne , Texas
If you could find a parking lot with speed bumps that might help evaluate the effectiveness of the axle. Here's what my '91 with original axles does over speed bumps: as each axle hits the bump it raises the trailer. I'd rather have each axle absorb the bump so that the trailer doesn't thump over the bump. How do new axles handle a bump like that? Also, What angle of axles are most commonly used, I was thinking of 22 degree for mine.
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley.
Tow With: 2006 Dodge 2500 Quad Longbox 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr programmer, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 06-07-2015, 08:22 AM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
When a wheel goes over the speed bump and the trailer raises, do the other wheels also raise or take the bump independently? What I am saying is I would expect the trailer to raise a bit, but the other wheels to act independently. I think 22 degrees down angle sounds about right. But, I don't consider myself an axle expert.
SOLD!! Gabriel Shocks for vintage trailers with Dura-Torque Axle apexdc Airstream Classifieds 0 05-09-2014 06:27 PM
Zip Dee Chair Storage Unit in 1990s> Airstreams mello mike Cabinets, Counter Tops & Furnishings 15 06-10-2009 03:26 PM
Not comfortable welding on the new DURA-FLEX axle PoconoAir Shocks 11 05-30-2007 05:15 AM
Dura-Torque Explained TomW Axles 18 04-07-2007 01:11 PM
Solo mileage of Dura-max engine Coloradobus Off Topic Forum 7 02-25-2004 05:42 PM
