Old 04-09-2017, 05:55 PM   #1
1998 25' Excella
Portland , Oregon
1 or 2 axles?
May have bent an axle. 1998 Excella 25'. The driver side front tire tread on the inside has worn severly in 100 miles. If I replace the bent axle do I need to replace the other? If just the spindle and arm are bent can I replace them and save the axle? Thanks in advance for replies and advice.
rspeirn is offline   Reply With Quote
Old 04-09-2017, 06:00 PM   #2
1986 31' Sovereign
Miami , Florida
You will have to replace the axle as the spindle is not a separate assembly.
You should replace both.
I would look hard at the wheel assembly, which may well be the culprit.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 04-09-2017, 09:16 PM   #3
1998 25' Excella
Portland , Oregon
Thanks for the reply.
Can you tell me what I should look for in the wheel assembley?
Old 04-09-2017, 10:24 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Get the tire off the ground while still on the coach. Spin the tire and check for run out or wobble. You may have bent the rim to the point where it doesn't rotate in a straight line.
Old 04-10-2017, 06:01 AM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Very good advice in previous posts. Start with the cheap and easy and work your way up.
1) Is the wheel mounted properly on the hub and lug nuts properly tightened? If not, remount wheel but probably will have to replace tire.
2) Has the tire thrown a belt causing a deformation in the tread leading to the uneven wear pattern? If so, replace tire.
3) Raise wheel, grasping the wheel pull and tug towards you, side to side and top to bottom. If the wheel moves in any plane other than turning and feels loose; check hub, bearings and races for excessive play.
4) Is the rim bent causing the wheel excessive run out as you spin the wheel? Replace rim and tire.
5) Now check your spindle and axle.
Cheers
Tony
Old 04-10-2017, 07:48 AM   #6
1998 25' Excella
Portland , Oregon
Thanks TG Twinkle and Isuzusweet. I am proceeding as you have suggested.
Old 04-10-2017, 10:04 AM   #7
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
There are trailer alignment shops that can fix correctable issues, from big rig stuff to light landscaping rigs.
Look in towns with a fairly big truckstop/highway hub.
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 04-10-2017, 03:24 PM   #8
1967 26' Overlander
Spartanburg , South Carolina
You didn't say why you think you may have a bent axle. I thought so too after a near crash in a very rough construction zone. A tire began to wear on one edge after a few hundred more miles. Rotating tires did not change things and inspection by a trailer repair shop revealed no misalignment. Then I signed onto this forum for the first time and learned the useful life of trailer tires is only 6 or 7 years. Mine were 13 years old. A new set of tires resolved the issue. By all means have an alignment shop check your rig. Any good alignment man can do it for you. In most cases misalignment can be corrected, but old tires can only be corrected by new tires.
Jacob D is offline   Reply With Quote
Old 04-10-2017, 03:57 PM   #9
1986 31' Sovereign
Miami , Florida
The only way to adjust the alignment of an Airstream axle is to bend it. There are very, very few shops that have the knowledge or equipment to do this.
The tire wear is indicative of a problem but it is unlikely that it is the axle.
Young, lovely bride
Dismissive cat
Axles: Dexter, Leaf Springs, Coil Springs, Straight Axles Ray Eklund Axles 22 09-10-2016 06:02 PM
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
Axles on a Avion 68 Suburban Axles 0 10-06-2002 12:10 AM
Motor Home Tag Axles - winner General Motorhome Topics 0 05-25-2002 04:56 AM
