Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 09-15-2005, 05:14 PM   #1
aviontt's Avatar
Profile:  , Connecticut
Thumbs up 1 or 2
Having 2 trailers of the same length 1 with 1 axle the other with 2 both are 25' one aprox 3400#2 axles the other 3250# one axle what are the pros & cons... 1 axle vs 2 axles
Worry will never change the outcome!!!
aviontt is offline   Reply With Quote
Old 09-15-2005, 05:23 PM   #2
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Airstream Registry
Cons... 4 tires/wheelbearings/brakes/two axles to maintain. Pros... no spare tire needed, smoother ride, easier backing.
Roger
AIR 2053 Current: 2006 Bigfoot 25RQ
Airstreamer Emeritus: 1953 Flying Cloud, 1957 Overlander, 1961 Bambi, 1970 Safari Special, 1978 Argosy Minuet, 1985 325 Moho, 1994 Limited 34' Two-door, 1994 B190 "B-Van"
Old 09-15-2005, 05:27 PM   #3
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
Airstream Registry
I would think that, given the trailers are both the same length and about the same weight, two axles would help distribute the load more evenly, thereby reducing frame stress. One axle good, two axles better!
Frederic
SFC Frederic Lynes
1971 Sovereign International
2004 F-350 King Ranch
AIR # 8239
TAC # US-7
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 09-15-2005, 05:48 PM   #4
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
Take two
With two axles, each axle is more lightly sprung which makes the trailer structure absorb less shock when going over a road irregularity.
With a properly balanced trailer, I have never been able to tell any handling difference on the road although some others claim differently. My first two trailers were single axle and both towed beautifully.
As for the no spare claim. True, but I had that experience a couple of months ago when a brake assembly failed internally. I towed about 13 miles at 30 mph, fortunately on a 4-lane road with wide shoulders. I made it OK, but it took goshawful forever and wasn't much fun at all. The trailer lists way over and passing traffic tends to sway it. I sure would hate to blow a tire way out in west Texas and have no spare aboard! It might take a half-day to get to help.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 09-15-2005, 06:06 PM   #5
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Question
And if you had the one axle when you had a brake assembly failure where would you be? Another plus for the 2 axle system.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-15-2005, 08:12 PM   #6
Profile:  , Minnesota
Images: 59
Airstream Registry
Single axle vintage trailers look nicer.
So there.
Old 09-15-2005, 08:18 PM   #7
fastrob's Avatar
Profile:  1976 25' Tradewind
Mount Vernon , Maine
1 for 2
I like redundancy,
It is twice as nice.
1 wife, 2 axles for stability.
fastrob is offline   Reply With Quote
Old 09-15-2005, 08:21 PM   #8
San Angelo , Texas
Images: 37
Airstream Registry
Yeah, but with two wives and one axle, you could put one wife up front and one in the rear, and it'd be stable too, right?
Frederic
SFC Frederic Lynes
AIR # 8239
TAC # US-7
EX-WBCCI # 8371
Old 09-15-2005, 08:23 PM   #9
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
Airstream Registry
Send a message via Yahoo to till
1 or 2....
I have towed both singles and duals. Dual is cool but a single is not bad when it comes to Airstreams. With a dual axle you have a little less to worry about when a blow out happens. If a single has a blow out it can be a big problem.
With you asking about which one, I would look at the interior as to how it suits you too. Assumeing you have two to look at.
Tedd Ill
AIR#3788
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 09-15-2005, 08:38 PM   #10
85MH325's Avatar
Images: 37
Airstream Registry
As for the no spare claim. I sure would hate to blow a tire way out in west Texas and have no spare aboard! It might take a half-day to get to help.
John's right of course... with a tandem axle trailer you CAN travel without a spare, but it's probably not a really good idea!
Roger
Old 09-15-2005, 10:42 PM   #11
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
A flat tire with one axle will most likely result in more body damage to the trailer. We have evidence of a PO flat...repaired badly. We will be replacing the street side panel off-season as a result.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
