Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Washer/Dryer & Dishwashers
Old 07-30-2007, 10:54 AM   #1
BrockLives's Avatar
Profile:  1972 29' Ambassador
Pittsburgh , Pennsylvania
Garbage Disposals
Has anyone ever done or heard of installing a garbage disposal (namely in a travel trailer)? If it's plausible, where would you route the waste, black or grey tank?
Brock
BrockLives is offline   Reply With Quote
Old 07-30-2007, 11:02 AM   #2
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Brock
Brock-
Why? Sounds like a lot of trouble to me. What would the advantages be? The less I fill my tanks the longer I can stay camping. Wouldn't it be easier to emty the garbage than empty your tanks? You would have to go into the black tank, the few states left that allow grey water on the ground would probably have a fit with the disposal dump.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 07-30-2007, 12:18 PM   #3
BrockLives's Avatar
I'm ground-up renovating for fulltime and a garbage disposal is something I'll really miss on the road. I figured if I am dumping the tanks anyway, it would be worth it, however I don't know exactly how one would set it up to work. Just curious to see if it's been done and how.
Brock
Old 07-30-2007, 12:23 PM   #4
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
You cannot do it for the following reason: Garbage disposals use a lot of water to grind and flush the waste. You don't have nearly enough capacity in the black water tank to accomodate all the extra water required. If you were permanently parked with a sewer hookup and fresh water supply, you might get away with it.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-30-2007, 02:26 PM   #5
Alumatube's Avatar
Profile:  Jefferson , Arkansas
I am not sure I would do this either -- you are looking at fats, oils, grease, fibrous waste from vegetables, waste break-down and rot, and probably other stuff I am not thinking about, and I don't think your tank (I would not even CONSIDER the grey tank for this) was designed for that stuff. Imagine fats and oils congealing inside your tank, on the sensors and fittings, etc., then consider what you would have to do to clean it! Bleah. I doubt those bacterial add-ins would be able to handle it, but I don't know that with certainty.
I just catch food waste in the sink and strainer and dump the trash often!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
1974 31' Excella (soon-to-be carhauler)
Alumatube is offline   Reply With Quote
Old 07-30-2007, 03:02 PM   #6
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Another problem would be connecting the garbage disposer to the sink drain. RV sinks have a much smaller drain than residential sinks.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 07-30-2007, 03:06 PM   #7
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 853
Some of the 345LE motorhomes have them...mine does not.
klattu is offline   Reply With Quote
Old 07-30-2007, 05:04 PM   #8
Profile:  2005 34' Classic
Richmond , Virginia
I think id stay away from that one.
Resorts is offline   Reply With Quote
Old 07-30-2007, 05:49 PM   #9
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
Misery is caused by putting things down the drain, thinking you are rid of them forever, then discovering that they are not truly gone.
Please rethink putting anything down the drains that is either not completely liquid, or that has not passed through you first. Unless it is designed for your tank, such as the appropriate chemical, or tp designed for rv use.
Pat
pmclemore is offline   Reply With Quote
Old 07-30-2007, 08:23 PM   #10
Foiled Again's Avatar
Profile:  2005 22' International CCD
Virginia Beach , Virginia
Advice so good it needed to be said twice!
Pat
"Disposal" is a Madison Ave. term for what the Navy calls a GARBAGE GRINDER. It doesn't ultimately dispose of anything. Everything you put into a black tank, you're going to see (and smell) again and believe me as the niece of two plumbers, ground garbage can be worse than sh**. (Think of food as just raw unprocessed sh**.)
It can and does congeal into lard-like globs and it literally can take weeks to pass from your home drains to the city sanitation center. Your black tank has an almost flat bottom. It would develop a 2 inch thick layer of this stuff and you'd probably have to flush it with many, many gallons of near-boiling water to dissolve it sufficiently for most of it to drain. You sure wouldn't want to try dran-o to move that crud out of your black tank.
I'm fulltiming and I moved out of a house with a garbage grinder. In a week or two, you'll adapt and never miss the disposal.
I'm in the habit of taking a tall kitchen plastic bag and hanging it over the edge of the cabinet drawer in front of the sink when I'm doing major food prep like peeling potatoes. I use a screen over the drain and a collander, dumping it into the bag as I work. When I'm done, I put any other trash I have in the bag and leave the whole house trash/garbage free. My stream is small enough that I don't want trash accumulating for more than 2 days max - so if I have to take the trash out almost every day, what does it matter if it also contains lettuce leaves, or leftover chili?
Happy trails to you...
Paula
Today is a gift. That's why they call it "the present"
Foiled Again is online now   Reply With Quote
Old 07-30-2007, 08:33 PM   #11
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
It is recommend you "do not" have a garbage disposal installed in homes with a septic tank.
Don't know about installing one in the AS but if you do let us know how it works out.
Garry
Old 07-30-2007, 09:41 PM   #12
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Garbage in Garbage out.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174,WBCCI 5131
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Check the weather at my home
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KLANEWOR12
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is online now   Reply With Quote
Old 07-30-2007, 10:13 PM   #13
bobfowler's Avatar
Profile:  1972 Argosy 20
2007 Base Camp
Middletown , New Jersey
Images: 14
<snip> Paula
If we ever meet at a campground, the beer is on me! That was the most poetic post I've read in a long, long time...
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
bobfowler is offline   Reply With Quote
Old 07-31-2007, 07:35 AM   #14
U.S.Navy Retired
Safari-Rick's Avatar
Lakewood , California
Another reason NOT to do it would be the buildup of the "heavy" garbage at the bottom of the tank (along as mentioned above with lard, oils etc.) Unless of course, you're willing to disconnect the black tank and clean it out?
As Paula stated, you're just asking for problems down the road.
Safari-Rick
Retired Navy ship fitter.
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Pingbacks are On
Metro-Detroit Forums Rally 2006 AYRSTRM2 Forum Rallies 1039 05-22-2007 12:51 PM
Wal-Mart Working For All of Us j54mark Towing, Tow Vehicles & Hitches 8 12-13-2005 05:12 AM
Hantavirus Alert! jjonesnc Off Topic Forum 17 04-06-2005 08:02 PM
Computer Experts....IE 6.0 problem Pick Our Community 3 08-03-2003 04:03 PM
Argosy trailers 83Excella All Argosy Trailers 33 07-20-2003 10:43 AM
SEO by vBSEO 3.1.0
