Old 02-06-2017, 06:20 PM   #15
1972 27' Overlander
Denver , North Carolina
I just finished a 72 Overlander that year does not have a grey tank as others have said. The smaller hole is the black tank vent. And the grey water did not flow into the black tank. It is usually a separate 2 3/4 " sanitary pipe that Siameses after the black tank valve. Mixing black and grey is bad business for a variety of reasons not the least of which is the possibility of allowing gasses back into your trailer, you could also wind up with a heck of a mess should the black tank backup into your grey system. What you can consider is using your old fresh tank as a grey tank ( take a look inside you won't want your fresh water stored in that ). All tanks need a to be vented. On thing you might take a look at is a device called a Hepvco valve, this will replace the P trap under your tub the goes through the floor. Another idea I see above is the Natures head composting system, if you don't want to mess with a black tank these are a good option as are cassette or porta potties. Also, you'll probably need to replace the tank and the galvanized box it comes in - keep the foam angles thing cause I was not able to find a replacement for it and that is what provides the angle to make your tank Drain properly. In closing - if you need help, PM me , I'll be happy to help.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 11-09-2017, 03:24 PM   #16
nickclifford's Avatar
1972 31' Sovereign
felton , California
black to grey, divert valve ?
just about to have my black converted to grey & install a composting toilet but wish to use a divert valve so if next owner wants to go back to a flushing toilet, no issues.
is this possible? an easy valve to send shower & sink wash water into Black tank ? My Landyacht has a 21 black gallon tank ... so I guess enough for a few quick showers for weekend camping.
thanks
nickclifford is offline   Reply With Quote
Old 03-15-2019, 09:59 PM   #17
1986 34' Excella
Tai O , Lantau Island
thanks
Interested too
Mary- This Indulgent Life
Renovating a completely gutted 1986 34' Excella starting July 2019
https://www.thisindulgentlife.com
MCPC is offline   Reply With Quote
Old 04-10-2019, 11:20 AM   #18
ENFIELD , NS
me too
joeybravo is offline   Reply With Quote
black tank, conversion, gray tank, gray water tank, help wanted
Black tank only for gray and black water??? mmollema Waste Systems, Tanks & Totes 9 02-01-2017 04:36 PM
Black tank to gray tank conversion. Is it possible? Blu_Hwy_Lady Plumbing - Systems & Fixtures 11 03-11-2016 11:05 AM
Replacement black tank and new gray tank mingle51 Waste Systems, Tanks & Totes 3 11-20-2015 07:03 AM
Tank level monitor suggestions for new black/gray tank redreefet Waste Systems, Tanks & Totes 5 06-28-2012 06:39 PM
Anybody know if a black tank will fit in the gray tank space on my TT? Aage Waste Systems, Tanks & Totes 9 02-24-2010 04:13 PM
