Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Dehumidifiers & Ozone Generators
Old 11-28-2008, 02:24 PM   #1
catson4's Avatar
Profile:  1991 34' Limited
Port Orchard , Washington
Thumbs up Ozone Gens worked for me
See "ALUMIN8" post on previous page.
Ozone is a strong irritant to those of us with bad lungs or other allergies. Be carefull when using.
That said, here is how I used an Ozone Generator.......
The PO of my 34' AS was a VERY HEAVY SMOKER and had 2 little dogs that never went outside.. There was about 1/16" tar & nicotine on everything. A fingernail scraped down the wall left a grove.
After removing all fabric, cabinet doors & hardware, carpet and anything else not bolted down (and some that was) and 3 hard scrub downs,(had to hire it cleaned) I rented an Ozone Generator and ran it for a day with the trailer closed up.
I then left all windows and door open w/ fans running for 2 days. I was finnaly able to be inside the AS for more than 3 minutes without my heavy duty air mask. I have COPD. After removing the rear section of floor (7') I rented the O.G. again.
Painted the exposed frame with Por-15, installed new insulation, sub floor.
And again rented the O.Z. for another day.
The cost was $40.00 a day but now there is ZERO smell of the tobaco or molds.
I am going to rent one again come spring but then will only need it for about 4 hours. Very effective and for $15.00 for a part day, well worth the $$. I will just open all cabinet doors and fire it up, followed by a good ventilation process.
So, if it is mold or odors you want to get rid of, the O.G. is the way to go.
BUT JMHO
Claude
One bazillion fish
1991 34' 60th Aniversary Limited Edition #008
2007 Chevy 2500 HD Duramax/Allison
One big parade float & a 40' Wells Cargo 5th wheel trlr.
"Wake each morning & Smile at the GREAT DAY you about to experience"
www.catson4ponds.com
catson4 is offline   Reply With Quote
Old 01-30-2009, 07:22 AM   #2
redhawkerII's Avatar
Profile:  1970 27' Overlander
Altus , everywhere GREAT
Images: 14
Send a message via Yahoo to redhawkerII
....ours is a peak 03 purifier...left knob turns ozone on and off...right knob controls ionizer. The ozone can 'clear' the air...I however had not heard of its effects on plastics. So heres my question....what is ion or ionization, and what does it do....I know people who live near large bodies of water feel better and feel worse when they are much further inland (away from water) Tell me I want to know!
.....Is there another word for synonym? " Life is like a bicycle...to keep your balance you must keep moving." Einstien, 1930...and lastly,-"Go confidently in the direction of your dreams, Live the life you,ve imagined"...Henry David Thoreau
redhawkerII is offline   Reply With Quote
Old 01-30-2009, 10:13 AM   #3
SJ1
Profile:  Currently Looking...
Stone Mountain , Georgia
I use an OasisAir purifier and am most pleased with it. Kills mold, fungus, viruses, and helps keep insects away. Air Purifier - UV air purifiers for Indoor Pollution
I also have a salt lamp, which generates negative ions, and like it very much.
But, the Airoasis has made such a drastic improvement, that I'll make sure I always have one.
I run it all day, all night, every day.
SJ1 is offline   Reply With Quote
Old 01-30-2009, 11:05 AM   #4
1972 Travelux Princess 25
Profile:  Cobourg , Ontario
You should also know that ozone deteriorates rubber, plastic, paint etc.
When your tires dry out and crack, or when plastic panels in an old trailer crumble, that's ozone at work.
I have an ozone generator and use it to dispel smoke and bad odors in my home renovation work. But you should use it cautiously and as little as possible. Close up the room, turn on the generator and leave. Let it run as short a time as will do the job. Then go in, shut it off, open the windows and leave for at least half an hour so the room can air out.
The ozone works by oxidizing everything it comes in contact with.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 01-31-2009, 06:55 AM   #5
dick&claire's Avatar
Profile:  2007 27' Safari FB SE
North Falmouth , Massachusetts
Ozone
Ozone is an unstable molecule consisting of 3 oxygen atoms. Oxygen has a valence of 2 and, thus, the stable molecule is two atoms of oxygen. Ozone has a negative charge since one of its free electrons is not shared. It is highly reactive and oxidizes other molecules, including those that cause odors of mildew or worse. When they are oxidized they don't stink anymore. Ozone can also oxidize other molecules, apparently including plastics...don't know much about that! We have used an ozone generator in the bilge of our previously owned boat and it was very effective in eliminating bilge odors.
Dick and Claire Wiklund
North Falmouth, Massachusetts
"Judgement is based on experience and experience is based on poor judgement"
dick&claire is offline   Reply With Quote
Old 01-31-2009, 10:01 AM   #6
By the way some nutritionists recommend taking "anti oxidants" for better health and to slow down aging.
So breathing something that CAUSES oxidation seems like a step in the wrong direction.
Old 02-02-2009, 08:11 AM   #7
Images: 14
Ha! I would take everything in moderation...We use a peak 03 and use the ionizer full time...and the ozone (03) part, we use when we go out on errands (full blast!) and then clear out the house upon return...all the while researching and asking people like yourselves about ozone and what it does...I had heard that this ozone process causes whatever impure thing is floating around, to adhere to any nearby surface...We currently are in Southeast Oklahoma where there is plenty of dust and got tired of wiping dust from monitor screens (tv pc etc) Before on certain days you could see dust particles hoovering in a sunbeam....
Old 02-04-2009, 05:34 PM   #8
somefun's Avatar
Profile:  1974 27' Overlander
Puyallup , Washington
I purchased a "Fresh Air To Go" by Ecoquest and started using it in our Airstream about a week ago. It's designed for approx 500 sq. ft. or less. I have been running it full blast while I'm at work, and the trailer definitely smells fresher when I return. Sometimes I will run it at a lower setting in the bathroom or bedroom, while I'm in the trailer. I'm trying to be cautious, though, because of some of the warnings I've read here and elsewhere on the internet about the effects of ozone on the respiratory system. These units retail for around $250, but they can be found on Ebay for about $50 or so (I paid $70 including shipping for a new one on Ebay).
somefun is offline   Reply With Quote
Old 02-06-2009, 10:01 AM   #9
Images: 14
I woke up this morning ...looked in a mirror, and looked younger! (just kidding)!
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 05:39 PM
Dumb Generator Question #2 Dave-O Generators & Solar Power 8 07-10-2003 07:26 AM
Generator No Start jim8860 General Motorhome Topics 6 05-03-2003 05:43 PM
Installing a Honda 4010/6010 generator PeterH-79MH Mechanics Corner - Engines, Transmission & More... 11 03-06-2003 07:19 AM
Generator Good News I Hope Paul Daugherty Airstream Motorhome Forums 3 02-06-2003 12:15 PM
