Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Dehumidifiers & Ozone Generators
Old 10-11-2009, 05:34 PM   #1
Deauxrite
deauxrite's Avatar
Profile:  2007 27' Safari FB SE
Hamilton , Texas
Heater + Dehumidifier question
Living in Southeast Alaska means cool days and nights and very high humidity most of the time. We run a small electric heater during the spring and summer and that does not seem to solve the moisture issues that we are encountering.
Is there a small heater dehumidifier combo that might do the job? One appliance would be better than two.
Living life on the Road
deauxrite is offline   Reply With Quote
Old 10-11-2009, 08:31 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
As a when-camping topic: Overnight I leave windows ajar in humid or cool conditions. This helps respiratory moisture inside equalize with outside relative humidity. Inside excess moisture condenses heavily on the inner skin/windows in the morning after nighttime cooling.
I open 1-3 windows a bit, turn the latch to prevent the window from closing -- and thus have a quarter to half an inch of circulation. I do this to a couple windows in cold conditions (15-25 degrees F), usually at the other end of the coach so I can sleep more comfortably -- and accept this as necessary even if running the furnace -- though the thermostat is rarely set higher than the mid to upper 50s. I set that approximately after lying awake and making sure that the furnace runs a bit and shuts off 2/3d's of the time or better. More than that you'll go through LP very fast -- and ya'd better have electric service at the campsite to run the furnace fan. A furnace fan in heavy use discharges the battery too much while dry camping. Batteries you intend to keep shouldn't be discharged beyond 50% or it will affect their service life.
Talking about storage and humidity is a different topic altogether. :flower:
Water Heater Question tdoescher 1969 Sovereign 2 04-07-2009 10:42 PM
Dehumidifier Foiled Again Dehumidifiers & Ozone Generators 9 11-08-2008 12:58 PM
Dehumidifier for Bambi 19' CCD CAK 2006 Bambi - all models 1 04-11-2006 07:11 PM
Dehumidifier? ipso_facto Interior Restoration Forum 0 02-09-2006 07:35 PM
Dehumidifier tincanholiday Dehumidifiers & Ozone Generators 8 09-08-2005 10:31 AM
