Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Dehumidifiers & Ozone Generators
Old 07-07-2003, 06:58 PM   #1
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
"Der Schmell"
I had a musty smell inside the coach that came and went. I would use my ozone generator and it would eliminate it for a few days, then it would come back. No leaks, no wet carpet, and it was not coming from the toilet.
Well, it got worse a week or so ago when I turned the A/C unit on for the first time. No doubt about it, it was the A/C.
My brother in law came over and we took the shroud off, and the cover on the evaporator coil. We cleaned the coil with a scented cleaner and rinsed it down with the hose. Boy, there was a lot of crap in there, no wonder it stunk! I'm not sure how old my A/C unit is, but it appears to be the second unit, as the original screw holes are plugged and we can see the outline of the older unit. I also do not have the right drip pan, and condensate runs down the side.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 07-07-2003, 07:29 PM   #2
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Good, just a musty A/C smell,
I figured it was another one of those nasty "black tank" threads.
Sounds like you got a handle on it. What you got up there, a Coleman?
Chas
Chas is offline   Reply With Quote
Old 07-07-2003, 08:03 PM   #3
Moderator Emeritus
Pick's Avatar
Images: 36
Chas, it is a Coleman.
Lots of Hot Sauce!
Air # 283
