I am looking to run a dehumidifier inside the Airstream at all times, I have looked at the threads but still have these questions. I am hoping to drain it down the kitchen sink and into my home septic, I will run it 24 x7 when its parked at home. Will it really help or is it like putting a humidifier and a dehumidifier in a room and letting them fight it out, I live in FLORIDA..... Is there a good economic brand? I would like to hear some tips - Thanks
Heaven is where the Chefs are French , the Police are British, the Beer is German and the Movies are American.
Hell is where the Chefs are British, the Police are German, the Beer is American and the Movies are French.
One thing to keep in mind is that your dehumidifier will be trying to dry out the water in the 4 traps, i.e washbasin, sink, shower and W.C. To prevent this I add a few drops of cooking vegetable oil to each trap before starting the dehumidifier. If you keep the windows, vents and door closed, the dehumidifier will have done its job after a couple of days, and you could experiment by switching it off. (ozone layer etc...), until the next time you open the door. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
Oh it will help a great deal. We don't deal with the extreme humidity like you have in Fla. but if I was doing it I might consider putting the dehumidifier in the shower basin. Much easier to allow the drain hose to dump in that drain than high up on a sink.
I have one in my basement and for all intents from a brand standpoint I think they are about the same. Most places sell either a unit that can eliminate 25 pints or 40 pints of water a day. The difference in these two are pretty much weight and compressor/evaporator size. If your trailer is closed up, a 25 pint unit will probably work well. If you leave a hatch open for ventilation, then it pretty useless.
It will usually have a thermostat so you can adjust the amount of humidty that it removes. The unit will cycle then which will save some electric.
The only other consideration is the heat from running the unit. In a closed trailer in the sun, that unit will be working under a high heat load. For all intents consider it a little refrigerator with the cold coils condensing the humidity and the exhaust heat dumping into the same area. I'm not sure what the effiency would be in that type of environment.
From a cost standpoint watch the sales and summer closeouts. Sam's Club usually sell some at a good price but at this point they probably have already switched over to their fall/winter seasonal stuff so you may not find any in stock.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
I considered that, i was wondering whether if i put it on a lo setting and just let it always run that it would shorten the life of the unit, the fan always runs when the air is on and then it boosts when the thermostat clicks on, i think they all do that. I wonder what that would do to my electricity bills, in summer I pay around 350 to cool the house..... and in winter our bills are around 150....... I want to try and avoid the musty smell and the build up of mold on the walls when it is not in use.
cant blame you for not wanting odor and mold in your coach!....and only the monthly bill will tell your cost..one thought would be to build a timer to turn the power on and off...are your electric rates different for off peak hours?
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
Yep it would. That A/C unit is much more expensive to replace than a $100-$150 dehumidifier. The other thing is once you hit set point on the A/C unit, it shuts off and the dehumidification process stops. What's worse is that A/C units with continously running fans reintroduce humidity into the air due to the coils being wet with previously extracted moisture.
A dehumidifier runs based on moisture content in the air. So it can be 70 degrees in the trailer and it will still run. Something your A/C compressor will not do if the thermostat is set a 78.
Jack
Jack Canavera
STL Mo. AIR #56
'03 GMC Savana 2500
I think I will go with the dehumid in the shower and then put oil in the traps and see what happens. I love this website, I have learned more on here than I ever did at College.
I run my AC for about 2 hours every week. Usually it stays hot enough to keep the inside dry. At 90 to 110 degrees, your not going to have much moisture buildup. Usually keep a window open and the Fantastic Fan on thermostat. I think I have worn out the motor now, though!!
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
