Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Dehumidifiers & Ozone Generators
Old 09-02-2005, 11:17 PM   #1
Foiled Again's Avatar
Virginia Beach , Virginia
Dehumidifier
I'm fulltiming in a 22ft CCD and even though my air conditioning keeps the unit nice and cold, there is still a humidity issue. Hey, it's Virginia in late summer; the humidity is always 98% or higher. One source of stored humidity seems to be my foam mattress - which I don't like anyway. I'm replacing it with a custom inner spring one (oval so I can turn it side to side - I'll use pillows in the inside corners).
I'm looking for a very compact dehumidifier too. Any ideas?
Tin Lizzie
Old 03-20-2008, 04:24 PM   #2
Profile:  2008 27' International CCD FB
Venice , Florida
Dehumidifiers
Try using google and search on "marine dehumidifiers". Boats have the same problem as those of us in FL. I found a "DH-5" but have not been able to track down who manufactures it. Nor have I not found any brand name to go with that model number.
Hope this helps.
ThunderHawk is offline   Reply With Quote
Old 03-20-2008, 06:55 PM   #3
Profile:  1977 29' Ambassador
Brandon , Mississippi
We bought a Walmart special. It fits between the two recliners and does a dandy job.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
'Epiphany' the 29' Airstream and a honkin' long 34' named AlumaTherapy
Old 03-22-2008, 08:11 PM   #4
Vintage Kin
REDNAX's Avatar
Profile:  Beaumont , Texas
I purchased an upright unit from LOWES, it does the job and then some. One needs a good estimate of the cubic footage of the trailer interior to make a sensible purchase. As to marine pieces, a long time favorite for storage is the GOLDEN ROD. See WEST MARINE.
My trailer is in covered storage and I hope to be able to move it before late spring to another covered space with electricity so that I can run the de-humidifier and keep the batteries charged up, etc. I'll place the dehumidifier in the kitchen sink and let it drain into the other side.
2004.0 DODGE 2500 Cummins 305/555; 6-manual, 7,400-lbs; 19 mpg city; 22-25 hwy; 13-15 towing. All miles at 1,700-1,900 rpm.
Sold: 1983 Silver Streak 3411 Supreme; 6,860# (8,000 GVWR)
Classified section, vintage kin
http://www.airstreamclassifieds.com/...p?product=6935
REDNAX is offline   Reply With Quote
Old 03-22-2008, 08:31 PM   #5
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
You did say small? I got one of these at a thrift shop for $4.00, but haven't had a chance to try it in the Bambi yet. It runs quiet, and I did notice it got some favorable reviews.
WindChaser Product Reviews and Ratings - Dehumidifiers - Mini Dehumidifier - WHDMW from Hechinger
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
Old 08-02-2008, 01:00 PM   #6
mustang's Avatar
Profile:  1986 31' Sovereign
Kent , Ohio
its nice to see other people find the humidity bothersome
mustang is offline   Reply With Quote
Old 09-02-2008, 06:16 PM   #7
Vintage Kin
REDNAX's Avatar
I finally was able to get the 40' covered space with electrical I had requested last December. The trailer, big as it is at 34' is dwarfed by the motorhomes around it.
Corpus Christi has high humidity, and high heat. I set up the de-humidifier to run on the lowest setting ("Normal") and it filled the gallon bucket in less than a day. I emptied it, and set it to a higher setting ("Dry") and it filled the bucket in about a day. I emptied it, and set it to yet the highest setting ("Maximum") and need to go back . . .
. . and get out the instructions to find out how to rig that drain hose!
The trailer smelled a bit mildewy the day I moved it. But not since the machine has been running. I plan to leave it a little between the two lower settings and watch the electrical consumption to keep a tab on it.
Old 09-02-2008, 09:47 PM   #8
mustang's Avatar
Kent , Ohio
What if you set it one the counter or in the bathtub and let it drain in the sink or tub drain?? You can crack the grey water valve and let that drip.
Old 09-03-2008, 07:22 PM   #9
Vintage Kin
REDNAX's Avatar
I'll set it up in the kitchen sink as that is close to central; just need a rubber mat so it won't slide as it vibrates (compressor operating), and a drain hose. Very pleased I've gotten it.
Old 11-08-2008, 12:58 PM   #10
I finally had a free day to 'piddle around' and decided to complete the dehumidifier install. It's been sitting between the recliners and doing a fine job but I have to admit, it's kinda a pain to drain. I replaced the univolt after frying ANOTHER battery and freed up the space behind the dehumidifyer so here's what I did.
The Univolt had a vent that went through the floor so I added a drain to the Dehumidifyer and plumbed it out the old vent. Now my rubber bungee cord not only holds the dehumidifyer in place, it also keeps the condensate tub from wiggling out and shutting off the unit.
Now I never have to drain the thing again!
ID:	71071   Click image for larger version
Hi Ho Silver RV!
Never used a generator before- need help?? John Generators & Solar Power 13 04-12-2005 05:39 PM
Hantavirus Alert! jjonesnc Off Topic Forum 17 04-06-2005 09:02 PM
Bambi Flood Jemac Winterizing, Storage, Carports & Covers 12 01-16-2005 10:19 AM
yet another leak thread Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 12-10-2004 01:49 PM
Thawed Rubyslipper Our Community 5 02-13-2003 07:25 PM
