Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Nu-Tone Appliances & Central Vac System
Old 11-15-2012, 10:47 PM   #41
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I was at Sears and found a 5 hp oval shop vac. with all the attachments. It uses standard
vac accessories. It will live in the closet I also picked up a 25' hose.
Gee if the Tahoe needs to be vacuumed I can take it out of the closet.
The best part is it only cost $79
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-15-2013, 05:00 PM   #42
1977 31' Excella 500
Savona , New York
I have a 1977 Excella with factory central vac. And is mounted under bath room sink counter, open trap door under sink counter plug in vac hose turn on switch on bath room wall, access to canister thru outside rear door. houndjfp
JimP is offline   Reply With Quote
Old 03-18-2014, 04:12 AM   #43
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
Northborough , Massachusetts
We had added central vac to our Cutter. We are now in the final stages of a shell off complete remodel of our '68 Tradewind. We will either add a central vac again or get the cordless Dyson. We really like the central vac. I believe we can fit it in the Tradewind without loosing too much. We had a Dirt Devil, but I see some other suggestions in this thread. Any new one's that we should consider?
Planning the next trip....
New England Unit....in Fun, Fellowship and Adventure.
Pam is offline   Reply With Quote
Old 03-18-2014, 04:49 AM   #44
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
We are putting a central vac into our Excella. Research led us to the Intervac brand. We will let you know how we like it after it is in!
Skatiero is offline   Reply With Quote
Old 03-18-2014, 05:21 AM   #45
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
We're comparing function and price. The Dyson DC35 is about the same price but is light weight, compact and cordless. This might win out over the central vac for us.
Old 03-19-2014, 11:22 AM   #46
Vroom Quick-Clean Central Vacuum Accessories
I posted this once before. It's a nice little central vac.
Rich the Viking
VIKING is offline   Reply With Quote
Old 03-20-2014, 06:52 AM   #47
Pam
Pam's Avatar
1967 17' Caravel
1968 24' Tradewind
We're definitely leaning toward the Dyson upright vacuum for size and cost, instead of the central vac, after all things considered.
Old 03-20-2014, 07:02 AM   #48
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Gadgetitits???
Old 03-20-2014, 07:12 AM   #49
1987 25' Sovereign
Oregon , Ohio
I have installed three central units myself. Two in our homes and one for a friend. With a central unit mounted in the middle of the RV and the standard 30' hose you could vacuum a 50' RV. Seems to me that a central unit plus hose and attachments would take up a lot of storage space. I have been considering the Dyson cordless upright, but my wife still likes the broom, brush and dust pan. as all us husbands know, if momma aint happy, aint nobody happy.
msmcv51 is offline   Reply With Quote
Old 03-20-2014, 07:12 AM   #50
ottawa (greely) , Ontario
Cool
Our trailer is too small for central vac ,but we do carry a shop vac that can be used by our 600watt inverter when boondocking ,it's also great to clean the truck up and it's wet dry vac, and very affordable at $39 dollars, I like the dyson dc 35 but it only runs for 15 minutes and takes 3.5 hours to charge,it's ok in the trailer but I cannot vacuum the truck and trailer back to back.
scamp is offline   Reply With Quote
Old 03-20-2014, 07:22 AM   #51
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
We installed a vac pan in our Excella. It is part of the central vac. It works like a built-in dust pan-- a covered opening in the tie kick---you sweep into it and all the dust and dirt go into the central vac.
Old 03-21-2014, 07:22 AM   #52
1987 25' Sovereign
Oregon , Ohio
I put a vac pan in the first house install I did and it was a very nice feature.
Old 03-21-2014, 11:15 AM   #53
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
Rich the Viking
Rich; I like the Vroom design, might consider one of those for my house and cat litter tracking issues. It could be a better fit than my Intervac in post 33, but the long hose covers the entire moho, and it has lots of power.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
TerraYacht is offline   Reply With Quote
Old 07-23-2015, 06:34 AM   #54
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Seems to me that every Airstream we own I install a Dirt Devil central vac unit to it. With the dog it makes clean up an excellent job. In our 2005 Classic Limited 34' S/O I mounted the unit underneath the wardrobe cabinet next to the water pump with the outlet facing the hallway, it's in the middle of the trailer and makes it easy so you don't have to stretch the hose to it's extreme end. The accessories are stored in the cubby in the floor of the wardrobe. Our 390XL was a more difficult install. Because of the length I wanted two outlets, one for the bedroom, and one for the living room, this was acheived by mounting the Dirt Devil unit in the basement c/s next to the water pump access door and running the hard plastic PVCl iines fore and aft. The bedroom line runs through the c/s wheel well and up through the rear furnace compartment, the front outlet runs through the basement ceiling up into the refrigerator compartment facing forward near the dinette. The 325LE was a little more simple, only one outlet was required so the Dirt Devil (agian) unit was mounted on the ceiling of the R/S rear exterior compartment with the hard plastic lines routed through underneath the false floor of the bedroom wardrobe cabinet into the hallway just behind the shower. If anyone is interested in pictures let me know. My 4th install will be soon as we are picking up our new to us 2007 396XL from Bill Thomas next week.
bobmiller1 is offline   Reply With Quote
Old 07-23-2015, 07:14 AM   #55
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
We have a Dyson DC35 in the house, we pack it into the airstream when we travel, breaks down and stores easily in the closet.
I would love to have one full time in the airstream, but it is a big ticket item!
When we get home, I drag in the big Dyson for the mega clean up jobs
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 09-19-2016, 05:44 PM   #56
Lenox , Iowa
Had a vac in my 1975 35 ft class A Moho. 20 ft. Hose needs more space than the vac. We use a Oreck 110 volt handheld and took it the hole house vac.
Wragans is offline   Reply With Quote
Old 09-19-2016, 07:01 PM   #57
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have a Dirt Devil central vac still in the box for sale. Send me a PM if you are interested
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 07:41 AM
'78 Argosy central heater motor home edmatlock Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-22-2002 10:57 PM
Rotors for vacuum disk brakes wvmiller Brakes & Brake Controllers 4 10-21-2002 04:43 PM
Mexico and Central American adentures???? Frank On The Road... 2 07-07-2002 03:06 PM
Forums vs. Central ViewRVs Airstream Motorhome Forums 3 03-17-2002 11:47 AM
