Go Back   Airstream Forums > Airstream Marketplace > For Sale & Wanted > Parts Archive
Old 08-29-2003, 07:21 PM   #1
Paul Schaefer
Profile:
Question wheel hub cover for 1960 Overlander
I need a wheel hub cover for a 1960 Overlander. Dimension: 2.440" or 61.9mm. Please suggest sources.
Paul Schaefer is offline
Old 09-10-2003, 08:59 PM   #2
Deppdog
Profile:
Assuming you have the same style of wheel as I do on my 1962 Overlander, I have found a great solution thanks to another member here. There is not a direct replacement, but if you don't mind spending some $ and replacing all 4 wheel covers, Bob Drake is the man. Take a look at their web site for repop Ford wheel covers that will work. www.bobdrake.com. The part #s for mine were 01A-1130-BM for the hub caps and I also added beauty rings - 01A-18303-15. A very cool look! Pricey though... My wheels are 15" and have a series of clips around the center that the caps clip on.
Hope this helps!
Steve D
Deppdog is offline
Old 09-11-2003, 06:45 AM   #3
Paul Schaefer
Profile:
Thumbs up wheel hub cover for 1960 Overlander
Deppdog, Paul is away for a couple of weeks. Wanted to thank you for the reply though. He'll get right on that when he gets back!
[IMG] code is Off
61 Overlander furnace cover wildcat455 1958 - 1963 Overlander 12 08-13-2008 04:20 PM
Wheel Bearings for a 74 overlander AV8 Axles 5 02-03-2004 10:42 AM
Wheel hub leaking grease? rluhr Axles 13 01-19-2004 07:33 PM
Wheel and Hub Balancing plus Aluminum Wheels Cracker Wheels 1 11-05-2003 03:19 PM
Wheel Hub Temperature 74Tradewind Axles 4 07-23-2002 07:26 PM
