We have a 1972 Airstream. Does anyone know where we can get an aerial for it. Also how about a slide for the door.
Sherrie
Camping World and your friendly Airstream dealer both carry Winegard antenaes, depending on if you get amplified or non-amplified, they run from $100-120.
The slide for the screen door is available from Inland RV (909) 734-8130.
Screen door bug slide - Inland part number - 84119
Addional question - We have the aerial, but the gears are gone. Previous owner purchased new gears - still in the package and based on the packaging, they are probably well over 15 years old. If I remove the 3 rivets on the trim by the handle will I have access to the gears for replacement? Or, do I need to access from above. I'm guessing from the inside near the handle.
__________________ Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
Gears are on top of the trailer, and as long as the "new" gears aren't brittle from being out in the sun, they should be fine.
New question: I'm 6'2", 250lbs. What are my best options for working on anything on the top of my A/S? I need to do some AC work (AC is leaking inside and want to remove the covers for painting) while I'm up there working on the aerial gears. I assume I am only asking for trouble if I put my full weight on the A/S, but haven't thought of a better way yet.
Two 12 foot stepladders, across the trailer from each other and a stout piece of lumber between them over the trailer.
For those with a sense of humor, and are waiting in the wings with jokes, yes Mark is 250lbs, not Kimber.
