Go Back   Airstream Forums > Airstream Marketplace > For Sale & Wanted > Parts Archive
Old 07-19-2004, 09:43 AM   #1
Sharon Parks
Profile:
Television aerial
We have a 1972 Airstream. Does anyone know where we can get an aerial for it. Also how about a slide for the door.
Sherrie
Sharon Parks is offline
Old 07-26-2004, 08:51 AM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
If you don't mind the work the standard Winegard Bat wing model is what is used today.
The slider by the door is available form most Airstream dealers, or you can order it form Inland RV.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
thenewkid64 is offline
Old 07-26-2004, 09:02 AM   #3
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
Sherrie
Camping World and your friendly Airstream dealer both carry Winegard antenaes, depending on if you get amplified or non-amplified, they run from $100-120.
The slide for the screen door is available from Inland RV (909) 734-8130.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now
Old 07-26-2004, 09:02 AM   #4
sovereignrwe
sovereignrwe's Avatar
Profile:  1972 31' Sovereign
Oakdale , Minnesota
Screen door bug slide - Inland part number - 84119
Addional question - We have the aerial, but the gears are gone. Previous owner purchased new gears - still in the package and based on the packaging, they are probably well over 15 years old. If I remove the 3 rivets on the trim by the handle will I have access to the gears for replacement? Or, do I need to access from above. I'm guessing from the inside near the handle.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline
Old 07-26-2004, 09:10 AM   #5
overlander63
Images: 58
Gears are on top of the trailer, and as long as the "new" gears aren't brittle from being out in the sun, they should be fine.
AIR#2611
Old 07-26-2004, 09:13 AM   #6
sovereignrwe
Oakdale , Minnesota
New question: I'm 6'2", 250lbs. What are my best options for working on anything on the top of my A/S? I need to do some AC work (AC is leaking inside and want to remove the covers for painting) while I'm up there working on the aerial gears. I assume I am only asking for trouble if I put my full weight on the A/S, but haven't thought of a better way yet.
Mark
Old 07-26-2004, 09:19 AM   #7
overlander63
Images: 58
Two 12 foot stepladders, across the trailer from each other and a stout piece of lumber between them over the trailer.
AIR#2611
Old 07-26-2004, 09:33 AM   #8
sovereignrwe
Oakdale , Minnesota
For those with a sense of humor, and are waiting in the wings with jokes, yes Mark is 250lbs, not Kimber.
Mark
Old 07-26-2004, 03:04 PM   #9
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Mark.
You "CAN" walk and work on your roof.
The myth of "NO WAY" perpetuates over time.
Reason?
If several thousands of pounds of snow doesn't hurt it, you won't either.
If your not sure, call me and I will be happy to tell you how.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is offline
Old 07-26-2004, 03:46 PM   #10
John & Linda W.
Profile:
antenna
Sherrie
Go To web site - www.barkermfg.com They might have the type you are looking for.
John & Linda W. is offline
[IMG] code is Off
Television Program Inland RV Center, In Airstream "In the News" 17 07-23-2008 01:06 PM
Flat Screen Television Circuit JmesDean Electrical - Systems, Generators, Batteries & Solar 4 07-08-2004 11:58 AM
My television antenna plug on 77 international wayne.yl Audio, Video & TV 6 12-12-2003 03:47 PM
International Rally gwsullivan The Rally Zone 29 09-27-2003 06:14 AM
television - looking for great airstream couple sunny181957 Airstream Motorhome Forums 0 08-07-2003 10:27 AM
