08-24-2004, 08:13 PM
gunnyusmc
Livingston
Sewer Solution System
Selling new Sewer Solution System with Tetford Adapter.
It will not work on trailers without separate gray water tank, like mine.
Never used.
See Clasified section.
Don
08-25-2004, 08:20 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Don
well, it'll "work", but...um..... you might get some unpleasant backups.
I found a use for mine last month when I went dry camping...no place to dump the black tank, so I brought it home with me, and used my blue-boy (big one, 4-wheeler, with its own dump valve) to shuttle the contents to a location where I could access a septic tank clean-out. this required going through a cellar window, which was slightly above ground level, so I couldn't use gravity alone. the SS was just the thing. did the job handily, with minimal yucky-ness.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
08-25-2004, 09:30 AM
gunnyusmc
Livingston
Sewer Solution
Originally Posted by chuck
In my case the gray water dumps into the valve just below the shut off! If I used the Sewer Solution I would have black water in the shower and sinks!!
Don
08-25-2004, 09:57 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Don
same here. been there, done that. But I plan on retrofitting a grey tank....some day. you know how that goes...
Air:291
Wbcci: 3752
'73 Safari 23'
08-25-2004, 07:33 PM
1975 Argosy 26
1963 24' Tradewind
Seattle
smelly times
I know what you mean. I flushed the tanks once without closing the grey water valve by mistake once. Oh the smells I got in the shower for awhile. I learned my lesson fast! Otherwise, I like my SS.
Marc
08-25-2004, 07:36 PM
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas
, USA
I was once told to learn from my mistakes, but the same person asked me if I had ever learned anything before I screwed it up!!!!!
09-15-2004, 08:21 AM
gunnyusmc
Livingston
Sewer Solution
Never used.
Don
THIS ITEM HAS BEEN SOLD.
Don
