Go Back   Airstream Forums > Airstream Marketplace > For Sale & Wanted > Parts Archive
Old 07-17-2003, 11:30 AM   #1
Janet Nelson
Iguana Co-Pilot
Janet Nelson's Avatar
Profile:  Aurora , Illinois
Smile Radiator
Hi; We are looking for a radiator for our 1987 Airstream 210 Motorhome. We have the old one out, its pretty bad. Thanks
Janet Nelson is offline
Old 07-17-2003, 11:39 AM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I have heard that the radiators are hard to come by. One member had to have his rebuilt by a local shop.
You could try here
http://www.autoradiatorsdirect.com/wizard/default.asp
I ran a search and they say they have it, but I would check for sure.
Here the pricing is 345.95, but I would check the sizes.
http://www.radiatorexpress.com/produ...aia_id=1059409
Hope this helps
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
thenewkid64 is offline
Old 07-17-2003, 11:52 AM   #3
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Don't Know if this will work however I used radiatorbarn.com for my van. They did an excellant job.
>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Action is offline
Old 07-17-2003, 12:15 PM   #4
zduke4x
zduke4x's Avatar
Profile:
recore
There are reputable radiator shops in most areas that can recore your radiator and warranty it for much less than a new one. Be sure that your tanks on the radiatorcheck out ok, then be sure to get the same capacity core or even step up a little in the replacement....lol jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline
Old 07-17-2003, 12:33 PM   #5
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
i looked for a radiator last month and was refered to the local mugal supplier by napa. was told i have your radiator but i need the filler neck of the old one to make it work. havent removed the old one yet but when i do im going to put them side by side and compare. to insure they are the same. they were going to install the filler neck at no charge. cost for radiator about $350 which is not bad for a big four core radiator. wouldnt mind getting a six core if i could find one.
have you had your radiator checked you might be able to get it rodded out and acid bathed and be ok.
i had mine done last year and the shop short changed me only rodded out and didnt acid bath. i think it is starting to cloog up again. plus i had a fan come lose and did some damage.
it is a bear to remove . lol
al
wb13798 is offline
Old 07-18-2003, 09:59 AM   #6
Janet Nelson
Iguana Co-Pilot
Rivet Thanks
Thanks so much for your help, Jan and Forrest Nelson
[IMG] code is Off
Radiator Coolant Change Out 87MH Mechanics Corner - Engines, Transmission & More... 5 01-28-2004 05:51 PM
Heater core, Door handle, Lower Radiator hose. josephhh Airstream Motorhome Forums 9 11-19-2003 09:20 PM
The Radiator Blues swebster Mechanics Corner - Engines, Transmission & More... 44 10-16-2003 11:07 AM
What's this? Radiator bag? TinCanSue Our Community 4 07-30-2003 07:01 PM
need to replace a radiator cap stuart1 Mechanics Corner - Engines, Transmission & More... 1 10-28-2002 02:12 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
