Go Back   Airstream Forums > Airstream Marketplace > For Sale & Wanted > Parts Archive
Old 09-07-2003, 06:47 AM   #1
live2dive
live2dive's Avatar
Profile:  1969 27' Overlander
mideastern , Michigan
Need cover for ThermX heater
The front cover panel on the heater is missing in our Sovereign. Does anyone know where we might try to find one? It is a ThermX Mark V.
Any help will be much appreciated.
Lori
live2dive is offline
Old 09-07-2003, 05:32 PM   #2
Fun-Lovin
Profile:
Have you ever used that heater? If so how well does it work, and does it give of fumes bad?
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline
Old 09-07-2003, 06:03 PM   #3
live2dive
live2dive's Avatar
Hi Greg. We haven't used it other than lighting it just to test it. The owner's manual says "no fumes" or words to that effect.
Lori
Old 09-07-2003, 07:17 PM   #4
rluhr
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
We have a ThermX Mark III (?) catalytic heater which seems to be fine. We use it for about 10 minutes on cool evenings just to take the chill off before bedtime. It seems to operate perfectly -- no fumes -- but just the same I make sure it is off with the gas petcock closed before going to bed.
The biggest problem with it is that it cranks out a LOT of heat. Even on the lowest setting we can't run it with the side couch converted to a bed, because it will scorch the blankets and sheets.
- RL
rluhr is offline
[IMG] code is Off
Inside hot water heater cover davidz71 Water Heaters, Filters & Pumps 12 03-24-2008 08:11 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
40+ year old heater 59toaster Furnaces, Heaters, Fireplaces & Air Conditioning 6 09-08-2003 06:35 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
What kind of paint for a louver cover for a wall panel heater cindy General Interior Topics 1 09-19-2002 08:38 AM
