Go Back   Airstream Forums > Airstream Marketplace > For Sale & Wanted > Parts Archive
Old 05-04-2004, 12:01 PM   #1
BIG BOW
Profile:  Sumter , South Carolina
DC Power Plug
Need a 7-pin DC power plug (trailer end) for a 1977 Overlander. Does anyone know where I can get one?
Gened is offline
Old 05-04-2004, 12:28 PM   #2
Janet's Husband's Avatar
Profile:  Eastern , Washington
If you are talking about the trailer to vehicle connector, it is available at any RV parts house, online, and at most auto parts stores.
Peace
Gary
Janet's Husband is offline
Old 05-04-2004, 01:07 PM   #3
sander17's Avatar
Profile:  1996 28' Excella
Okemos , Michigan
Images: 42
Trailer connector
Another source is a hitch shop.
sander17 is offline
Old 05-04-2004, 02:33 PM   #4
BIG BOW
I need the trailer end, not the vehicle end.
Gened is offline
Old 05-04-2004, 02:56 PM   #5
sander17's Avatar
Okemos , Michigan
Images: 42
A good hitch shop should have both ends. Or try camping world.
sander17 is offline
Old 05-04-2004, 03:09 PM   #6
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Even Wal-Mart will have it. It just might not be the best quality as an RV dealer.
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline
Old 05-04-2004, 03:41 PM   #7
MrTimbo
Profile:  1975 31' Sovereign
Newberry , South Carolina
Gened,
Are the pins in your connector round or flat? My 1975 has round pins in the connectors, I'm sure someone sales them but I don't know who. I switched the round pin connector to a flat pin so that it would hook up to the more modern vehichles. I live in Newberry and probably could find the plug that I took off, if you are interested.
Tim
MrTimbo is offline
Old 05-04-2004, 03:53 PM   #8
BIG BOW
Thanks,Tim. My pins are round with the larger one on top, not in the middle. I would really appreciate any help since Camping World, Walmart, etc., and the local hitch shops don't have it. If I can't locate one, I'll be forced to change out the trailer receptacle. If you can locate it, please contact me at: kduke@sc.rr.com
Gened is offline
Old 05-04-2004, 04:43 PM   #9
Airstream 1975!'s Avatar
Profile:  Cary , North Carolina
Does the plug say signal stat? I just repaced mine on the trailer end. I had to got to the 7-way flat. I could not find a replacement signal stat. I used one from walmart. I had to modify the plug though to properly fit in the front of the AS.
Airstream 1975! is offline
Old 05-04-2004, 04:43 PM   #10
dinoburb's Avatar
Profile:  1982 34' Limited
Tidewater , Virginia
They exist!!
Hi Gened,
I had the same problem with my '78 Sovereign and I found the correct plug here:
http://www.sheltonhitch.com/proddeta...418&catId=1070
The correct receptical if needed is also available:
http://www.sheltonhitch.com/proddeta...419&catId=1070
These are also available in plastic as well but I'm not sure of the manufacturer. I'll check.
Found the source for plastic trailer mounted receptical. I recommend the trailer mounted unit be plastic to remove the problem of electrolosis from dissimilar metals. These folks have the plug as well as the receptical.
http://www.truck-lite.com/webapp/wcs...0340&langId=-1
I used the cable end on my pig tail and it worked perfectly. I was able to salvage the original trailer mounted socket, so now my pigtail system works as it was designed! My trailer end is round pin and the truck end is blade, nearly Murphy proof!
Remember Okeefe's corollary: Murphy was an optimist!
Hope that helps.
Take care,
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline
Old 05-04-2004, 04:50 PM   #11
Profile:  1958 26' Overlander
Tijeras , New Mexico
Any airstream dealer will have them - if you call Oasis in Tuscon, they will ship it to you. They do not however, make the plastic "squarish" ones anymore - the new ones are round - but fit (I replaced mine) and easy to find. Any yes I'm talking about the ones with the round pins.
Ken
1958 Overlander
Ken J is offline
Old 05-04-2004, 05:58 PM   #12
BIG BOW
Hey Guys,
Thanks a lot for the info. You solved my problem.
Gened is offline
[IMG] code is Off
Pingbacks are On
power cord end Rick's73 Electrical - Systems, Generators, Batteries & Solar 6 07-29-2003 08:34 AM
Newbie needs Classic 28' power management info Dave Jenkins Electrical - Systems, Generators, Batteries & Solar 3 07-24-2003 05:11 PM
Hot Power Cord GoldFever Electrical - Systems, Generators, Batteries & Solar 7 07-13-2003 05:49 PM
power boosters John Our Community 18 11-19-2002 03:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
SEO by vBSEO 3.1.0
