I wish you well, but for a 59 model I have to bet that you will have to have it made. But maybe the 59s and the 79s are no different in the "wrap" dept. I do not know. Good luck.
But your request brings up a good opportunity for some clarification.
I have been under the impression that any of the "wrap" between the lower outside wall skin and the bellypan center course was properly known as "Banana Wrap" . I now wonder if only the corner sections (which are compound curved) are actually what is meant by "Banana Wrap".
If the latter is correct then what are the "straight" curving-under pieces between the corners properly called?
