Go Back   Airstream Forums > Airstream Marketplace > For Sale & Wanted > Parts Archive
Old 11-02-2003, 01:17 PM   #1
startrekker2001's Avatar
Profile:  1978 31' Excella 500
Palm Bay , Florida
Images: 34
BAL Stabilizer Jacks
Does anyone know the Model number of the BAL stabilizers that replace the BAL 20-13-TAL model I have on my '78 Excella? I have tried several avenues to get that info including the BAL website.
I have one jack that is broken because the PO apparently tried to lift the coach with it. If I am going to replace one, might as well do the set.
Vic
Vic Smith
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline
Old 11-02-2003, 02:51 PM   #2
Profile:
Have you emailed A/S tech support? They may be able to give you this infor via your VIN#.
John is offline
Old 11-02-2003, 06:47 PM   #3
Palm Bay , Florida
Images: 34
John
Thanks for the suggestion. I just emailed Tech Support. I had called them before and got no response.
Vic
Vic Smith
WBCCI #6782
Old 11-02-2003, 06:50 PM   #4
Ken J's Avatar
Profile:  1958 26' Overlander
Tijeras , New Mexico
Hello Vic
Hows the polish job holding up? I did finally put a picture of ours in the photo section.....
As far as the BAL jacks go I always thought they were all the same....?.......
Ken Johansen
Ken J is offline
Old 11-02-2003, 07:52 PM   #5
Profile:
Vic,
I've had better luck via emails than the phone!
Ken,
Your trailer looks good!
John is offline
Old 11-02-2003, 08:10 PM   #6
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
BAL Jacks
The BAL jacks for Airstream have a different lenght drive screw.
It is extended so it will reach the outside of the trailer. I think the rest of the jacks is identical to the ones from their website.
I just purchased a set from InlandRV. I am not sure if they have individual ones for replacement available. Perhaps Airstream has them??
Uwe
www.area63productions.com
uwe is offline
Old 11-04-2003, 02:23 PM   #7
airstream4's Avatar
Profile:  1997 34' Limited
1963 22' Safari
Troy , Michigan
I had same problem when I purchased my trailer in 2001 and purchased replacement thru camping world after talking with BAL and getting parts info. I'm in florida now but will be home in 10 days and will forward parts info from mine. very easy replacement when you have the right part.
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline
Old 11-05-2003, 10:20 AM   #8
fundave's Avatar
Profile:
Send a message via Yahoo to fundave
im looking for the crank that you use to set these jacks..?
Any suggestions
fundave is offline
Old 11-05-2003, 10:31 AM   #9
uwe
418
uwe's Avatar
Images: 41
Get a fitting socket, adapter and use your Makita cordless drill. You do have a Makita cordless drill, don't you?????
Then, to do the final turn or two, use a ratchet handle on the same socket.
It looks to be a 3/4in or 19mm hex
You can also buy an inexpensive 3/8 drive crank handle, and use the appropriate socket for it.
Uwe
uwe is offline
Old 11-05-2003, 04:34 PM   #10
Palm Bay , Florida
Images: 34
Thanks all for your assistance. I sent an E-mail to Airstream and got an answer back. The airstream part number is 400093. A call to the nearest AS Dealer in Alachua Florida got me a price of $205.
Undaunted I called BAL and asked what the replacement jack was for the 1978 Airstream TT BAL model 20-13-TAL. They came back with 22356.
I called Camping World, ordered the BAL jacks at $158 plus $20 shipping and it will be drop shipped to my house.
I did forget to order the feet though. But they are available locally.
BTW, the BAL jack handle is model 20023. I didn't get a price since I have one.
Thanks again. This forum is just loaded with nice folk.
Vic
Vic Smith
WBCCI #6782
Old 11-12-2003, 07:05 PM   #11
uwe
418
uwe's Avatar
Images: 41
Pictures
Here are a fw pictures of the Airstream specific BAL jacks on my trailer.
This shows the hex protruding from under the belly wrap. These work better than I imagined, which means they are almost worth the money and time i spent.
Uwe
uwe is offline
Old 11-12-2003, 07:08 PM   #12
uwe
418
uwe's Avatar
Images: 41
More pics
BAL jack streetside, new grey tank plumbing and new rear belly pan visible.
Uwe
uwe is offline
Old 11-12-2003, 07:10 PM   #13
uwe
418
uwe's Avatar
Images: 41
3rd picture
Curb side rear
Uwe
uwe is offline
Old 11-12-2003, 07:15 PM   #14
uwe
418
uwe's Avatar
Images: 41
more pics
front stabilizer jacks
Uwe
uwe is offline
[IMG] code is Off
Stabilizer Jack Installation uwe Jacks, Stabilizers, Lifting and Leveling 16 11-11-2004 06:39 PM
frozen stabilizer jacks silver suz Jacks, Stabilizers, Lifting and Leveling 10 03-24-2004 11:12 PM
How many stabilizer jacks are standard? Janet All Argosy Trailers 3 03-13-2004 11:09 PM
BAL Stabilizer Jack BASE PADS BOBHASTINGS Parts Archive 6 03-13-2004 01:10 PM
Bal Stabilizer lubrication mandolindave Jacks, Stabilizers, Lifting and Leveling 4 02-19-2004 10:51 PM
