Go Back   Airstream Forums > Airstream Marketplace > For Sale & Wanted > Parts Archive
Old 01-31-2004, 04:25 PM   #1
jaco
jaco's Avatar
Profile:
Question A-frame to Body Saddle "Transition Gussets/Fillers"
Seeking info on a pair of body parts on my 74 Excella.
I would imagine these are on every model of Airstream and I think they might all be the same (I hope) other than being RH and LH handed.
I will (for now) call them transition gusset plates or fillers.
They dress up the opening in the lower (below rub-rail) skin, Where the A-frame comes out from under trailer. They saddle the A-frame and rivet to the body skin.
I think mine are plastic, but am not certain. Hopefully they are aluminum. Mine have been painted and I don't want to fool too much with them yet.
The obvious questions please:
Are they all the same?
Are they available?
Cost ?
AS stock # ?
What are they really called? (I'll edit this post)
jaco is offline
Old 01-31-2004, 04:40 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
That part is called an A-frame saddle.
They are no longer available, and have not been used for many many years.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is offline
Old 03-17-2004, 12:16 PM   #3
jaco
jaco's Avatar
Profile:
Here is the saddle I was describing.
What is used on the later (and earlier Airstreams)?
Wonder how such a part was manufactured? Lots of curves!
Could this saddle be used as pattern for cast aluminum one?
Easy? Very difficult?
jaco is offline
Old 03-17-2004, 01:02 PM   #4
dmac
Profile:  2003 25' Safari
Eden Prairie , Minnesota
They could be used to make a mold for fiberglass replacements. This would be a DIY job, see make a mold.
Dan
dmac is offline
Old 03-17-2004, 02:01 PM   #5
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
My '67 has nothing but what appears to be vulkem sealant at that interface.
TomW is offline
Old 03-17-2004, 04:51 PM   #6
nickcrowhurst
Profile:
Jaco, you don't want aluminum there. If aluminium contacts the steel A-frame when there is salt in the air, either from the sea or road treatment, electrolytic corrosion will occur. You can see this on many Airstreams. Glass reinforced plastic would be fine, but I use Vulkem, as mentioned above. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline
[IMG] code is Off
test
