04-22-2004, 07:17 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
The picture of the one on the right with the pup is in an Airstream...very cool!
check it out here
Shari
04-22-2004, 07:19 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Jack,
Someone at Marine Stove apparently has done it...check out this conversion Marine Stove
Aaron
WBCCI #XXXX AIR #2495
Guest
Thats where I originally saw it., and there was a link to the site. They look great ...but pricey.
Jack
04-22-2004, 07:22 PM
1968 22' Safari
1976 27' Overlander
Newport
Jack, that's awesome!!! It would be perfect for anyone that likes to camp in colder climates!.
I just would have the hardest time cutting the hole for the pipes!!!! Maybe in one that had a dent in it already, then cutting up the skin wouldn't hurt so bad.
Ron
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
04-22-2004, 07:50 PM
2004 25' Safari
Cool restoration, but all I'd have to do is tell the wife we're going to heat the trailer with wood. Things would be a lot more than cool . We heat all winter with wood & I'm here to say that I'm more than happy to see the end of it in the Spring. Say what you will, but it's dirty, messy & maybe ??? cheaper than fossil fuel. I like it only because it's renewable.One good back draft in the trailer & We're gone.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
04-22-2004, 09:39 PM
Aurora
Very cool looking, but...
The renovation of that 1955 is beautiful, but... I have to wonder how the extra weight has affected it? Hardwood floors, cast iron (?) wood stove, stained glass panels, lots of stainless steel, and real tile in the bath. All of these are HEAVY! Back to the question though of a wood stove. It would be neat to step outside, chop some wood (to work up an appetite for dinner), and sit in the evening with a hot cup of cocoa watching the little logs burn. Very romantic. But if you're camped in the desert you would have to haul all your wood with you. Many areas prohibit the gathering of wood, and the wood stove does not duct the heat to the far ends, and inaccessible areas of the trailer. Remember, ducted heating keeps the holding tanks (on some models) and plumbing from freezing. I would only want to use a wood burning stove in a small primitive trailer.
Forrest
Out for coffee!
04-22-2004, 09:44 PM
check it out here
Shari
Yes!! The second one over with the black pup and the sofa. Excellent!! Gotta love that floor and the under-sofa storage!
The other photos are good for getting restoration ideas as well.
But 25K? Hmmm....
Regarding the wood stove, I'm skepical. As small as it is, it's going to need to be reloaded often with small (12") logs. Getting out of bed every hour to stoke it will get old fast.
- Charlie
2004.5 Dodge 4X4 Quad Cab w/Cummins Turbo Diesel
01-21-2008, 12:07 PM
1970 18' Caravel
Leavenworth
, Kansas
Has anyone tried this?
thanks,
--Dwight
01-21-2008, 01:00 PM
Always Airstreaming!
2005 22' Safari
1960 24' Tradewind
Anytown
, Connecticut
Between the 4" Pipe for the wood stove and the 4" pipe for the Bosh, I really wonder what the outside looks like up on top? I really don't see any advantage at all in having wood heat in any trailer. The BTU's you per pound of wood vs. prophane should settle the question before it is even asked. yes, looks cool, smells nice outside in the morning but I like to turn on the heat and call it a night.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
01-21-2008, 02:09 PM
Loganville
, Georgia
Wood pellet stoves
Wood pellet stoves are cleaner and I don't think you have to worry as much about your chimney. Check out the pro's and con's of wood pellet and wood stove. Wood pellets come in a bag and it looks like Guinea pig food. It burns very efficiently and the stove captures most of the heat. Our friends have a wood pellet and I was extremely impressed with it. I thought it did a better job then our soap stone.
I have a Soap stone wood burner in my house and it has been great. I does a great job on my two story house. I would think it would get extremely hot having even a small one in a trailer.
SIU Bound.
Brian
01-21-2008, 03:39 PM
I wonder how much that TT weighs...tile bath, hardwood floor, cast iron stove, maple counter top???
01-21-2008, 03:59 PM
Jupiter
Check out their 'Newport' solid fuel stove... about the size of a shoebox!
Dickinson Marine
*EDIT: took two tries to get link to stick....
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
01-21-2008, 04:13 PM
1973 31' Sovereign
Bertram
I love it when an old post comes back to life. True, axtra weight may not be what ones wants, but then again, not all of these old streamers are built for highway use. Pellets would probably be fine for a more mobile trailer. What I did experiance was a fifties vintage trailer that my friend maintained in northern New Hamphsire. This rig was very heavy, but since he set it up on a leased spot on a river he did not have to haul it often. It was completely boom dock...no power, plenty of wood. Four of us spent a great weekend in mid winter and all heat ws provided by a small pot belly stove. Exterior vent for combustion air a must. The unit they found is made for small spaces, should be perfect.
Catmando
"There’s not much in life we can’t over-analyze”
01-21-2008, 04:21 PM
INSANITY CENTRAL
1986 32' Excella
Airstream Funeral Coach
Citrus Heights
FWIW- I have a Newport 9000 by Dickinson, I'm happy with it in the Excella.
California has restrictions on wood burning stoves now- what next.
I did a thread a year ago -Heaters heaters heaters- describing methods to warm the rig.This Dickinson propane unit will run for 6 1/2 days straight on full using only a barbie sized tank. also Woodstock stove company in N.H. has a small soapstone stove suitable for use in a trailer.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
01-21-2008, 04:37 PM
Loganville
, Georgia
That Dickenson Marine looks great. I would love to have one of those. That would be a great for my trailer.
SIU Bound
Brian
08-16-2008, 06:58 PM
1977 31' Sovereign
Manchester
, New Hampshire
Love the idea BUT how do you do the pipe ?
How do you make a sealed water proof connection with a heated pipe like the exhaust of a wood stove .
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
08-17-2008, 06:06 AM
1965 20' Globetrotter
1956 22' Caravanner
Mendon
, Massachusetts
Dickinson
I just installed a dickinson newport in my 56 and ran it up the old chimney flue. But I still need to caulk the area around the pipe, just to avoid any water issues.
I have been looking at this product from Rutland 500 RTV, which is a high temp silicone caulk.
Any other ideas.
Doug
56' Caravanner 'The Broomstick'
08-17-2008, 06:15 AM
Retired.
, At Large
Any other ideas.
Doug
I'm sure you know the acids in rtv silicone are not conducive to aluminum. You could put a small piece of flashing around the chimney, and silicone that to the chimney. There's got to be a way to do this, I see houses everywhere around here with fireplaces and aluminum roofs.
08-17-2008, 07:45 AM
1977 31' Sovereign
Manchester
, New Hampshire
Dont the make a gasket material for wood stoves?
I beleive I had seen it on a stove pipe going into wall heat resistent .
K/N Cool intake air
Duel power exhaust
