Old 08-01-2013, 10:56 AM   #1
1975 31' Sovereign
Memphis , Tennessee
Wiring thermostat to Armstrong Bay Breeze A/C
There was no thermostat attached to the Bay Breeze A/C unit in my '75 Land Yacht when I purchased it. I have a replacement thermostat that I would like to install, but I am unsure of which wires go where. There are 4 wires to connect (brown, black, red, and green) to 4 points on the thermostat (Y, G, R, W), but I have no idea which go where. Thanks.
Ddanielgriff is offline   Reply With Quote
Old 08-01-2013, 11:28 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
This may help:
I know red is + and Green is low fan on mine. That is where my 75 differs. Your other 2 wires have to be high fan and cool. Not sure which is which though
The original thermostat was probably a Honeywell. With a switch for 2 speeds. Other "close on rise" stats should work but will probably only be set up for one fan speed setting (3 wire).
IF you seach my threads you will find a couple of very recent ones on the subject that may be helpful
Old 08-03-2013, 08:30 AM   #3
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
I just had to pull the bottom cover off my Armstrong, and underneath is a good schematic of the wiring
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
