Old 06-22-2011, 11:52 AM   #1
1986 34.5' Airstream 345
Tyler , Texas
Wiring a penguin
It seems its time to replace the AC units on the 345. I would like to switch to the penguins but am a little shy about the rewiring for the ccc unit.
Have any on the fourm switched and how did you pull the hard wire for
the CCC unit....I am going with 2 15,000 btu's because of the Texas heat and I cannot get around the hard wiring.
pjude is offline   Reply With Quote
Old 06-22-2011, 01:07 PM   #2
Images: 59
I think I would surface mount the wiring for the CCC unless you can route it to a nearby cabinet. It's only telephone cable so it's easy to hide behind a curtain, valance, or corner trim.
markdoane is online now   Reply With Quote
Old 06-22-2011, 01:52 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
FIRST.....how do you catch the little buggers.
Sorry couldn't resist
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-22-2011, 03:06 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
And what is the preferred method of wiring? Caffiene or sugar? Or both?
Seriously, the wiring for the controls isn't bad. You can run the wires across the roof to a cabinet, drill a hole and drop the wire down on the inside of the cabinet. Drill one more hole for the ccc thermosyat, plug it in, and screw it in place.
Old 07-08-2011, 06:35 AM   #5
Boerne , Texas
I like the finish of running the wires in the wall, if you check this thread on my installation you will be able to see pictures of how the walls are constructed and it may give you ideas on how to fish your wires. What locations are you trying to run wires to/from?
http://www.airforums.com/forums/f427...-in-75958.html
actually, the pictures are on my profile gallery.
Notice that the ceiling is where the original bundle of wires runs, you may be lucky enough to get a fish tape down there to the front A/C and pull your wires to where you need them.
James
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley.
Tow With: 2006 Dodge 2500 Quad Longbox 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr programmer, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Total wiring schematic joneslacey Electrical - Systems, Generators, Batteries & Solar 3 06-07-2012 09:20 PM
Dometic Penguin or Coleman Polar Cub for 1967 Caravel?? vonzellen Furnaces, Heaters, Fireplaces & Air Conditioning 20 08-13-2011 06:10 AM
Need Drain Hose Diameter for Penguin ASAP BrockLives Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-04-2011 05:59 PM
Prodigy P3 Wiring - 2011 Silverado Ganglin Brakes & Brake Controllers 0 04-17-2011 09:46 PM
Anyone have a wiring diagram for '75 excella? MonaxLisa Electrical - Systems, Generators, Batteries & Solar 13 03-27-2011 12:54 PM
