Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-30-2006, 04:48 PM   #1
firefly007
firefly007's Avatar
Profile:  1964 17' Bambi II
longwood , Florida
Hidden A/C
I am working on an A/C install for my Bambi II. The goal is
Quiet
Qool
Qant see it
Anyone interested
Steve
firefly007 is offline   Reply With Quote
Old 06-30-2006, 04:52 PM   #2
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Sure. Whatcha' ya got going on there?
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 06-30-2006, 04:55 PM   #3
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Windowless A/C
I'm looking for a windowless A/C unit for my Bambi II primarily because I don't want to destroy the original look of the trailer by adding an external A/C unit. I did an Internet search on windowless A/C and found lots of different models to choose from so am not sure where to begin. It looks like I can hide the unit in an existing cabinet where I can just open the cabinet door when I want to run the A/C. The exhaust for the hot air is routed through a tube that can be run outside. Some even have a dehumidifier option with a removable drawer to facilitate emptying the water.
Does anyone have one or know anything about them?
WBCCI Region One
"Repression provides a temporary solution." ~ Paul Williams
yukionna is offline   Reply With Quote
Old 06-30-2006, 04:59 PM   #4
yukionna
yukionna's Avatar
Images: 18
Quiet
Qool
Qant see it
Anyone interested
Steve
This has to be the ultimate coincidence on this forum. You and I both started a thread on the same topic (i.e., windowless A/C) and we both want one for the same model trailer (i.e., Bambi II). Too funny!
WBCCI Region One
Old 06-30-2006, 05:02 PM   #5
firefly007
firefly007's Avatar
longwood , Florida
Small split a/c system with cabinet mounted air handler and external condenser. Since the Bambii II is small and low it is quite a challenge. The end product must also be able to run on a Honda 2k generator. We are shooting at about 650 to 800 watts total power. The system may be marginal for full sun load at noon in Arizona but I am really looking for a good nites sleep.
Old 06-30-2006, 05:04 PM   #6
firefly007
firefly007's Avatar
longwood , Florida
Yukionna,
sorry did not see your post, where is it
Old 06-30-2006, 05:12 PM   #7
firefly007
firefly007's Avatar
longwood , Florida
Ahh, I found it,
You are right, you must have hit the send key at the same time.
I have never seen what I am doing, done. Could not find anything in the archives or on line. Maybe someone will post a past project I cant find.
I am used to building whatever I need whether it Flys, Floats or Rolls. I looked at all of the alternatives out there and they just won't do.
Old 06-30-2006, 05:42 PM   #8
yukionna
yukionna's Avatar
Images: 18
Oh yeah, forgot to mention, the real coincidence part is that we started our respective threads at the same time. Must be karma! Speaking of which, I will leave you some right now!
WBCCI Region One
Old 06-30-2006, 06:40 PM   #9
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
I want in.....
Don't keep this between you guys, share this info. I had two split type units installed on a CONEX this week for a work van to go an a ship. These were high end units by Carrier. Cost big bucks but every time I see them I get the idea for my Caravel. If you have a source for cheaper models let me know. As for now, all the one's I've seen are costly$$$$$$$$$.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 06-30-2006, 07:19 PM   #10
firefly007
firefly007's Avatar
longwood , Florida
Hi Michael,
There are several mini-split systems out ther for residential and commercial. Maybe you have seen something I have not but normally they are to big and clumsey for the inside of a Bambi and the outside units are are even less suitable. The inside and outside unit I am working on would go unnoticed by the average person. It is possible that this system can be offered as a product but it will be costly. I will update post on this project as I go if enough people are interested.
Old 06-30-2006, 10:37 PM   #11
robandzoe
robandzoe's Avatar
Profile:  1958 30' Sovereign of the Road
1965 17' Caravel
Plymouth , New York
Images: 26
65 Caravel
Contact Colin at GSM Vehicles, at www.gsmvehicles.com or on the forums here. They just did this in the 65 Caravel they customized and we are doing it to our 58 Sovereign of the Road. The house unit slides out the side of the trailer and drains to the ground, and is ducted through a closet. He's out at International now.
Rob
Rob, Zoe', Stanton, Bryce and Braedon Baker
WDCU President
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Courtesy parking (607) 334 4960
58 30' Sovereign of the Road:
http://sweetsovereign.blogspot.com
65 17' Caravel, 54 22' Safari, 1959 Buick Electra
robandzoe is offline   Reply With Quote
Old 07-01-2006, 08:21 AM   #12
yukionna
yukionna's Avatar
Images: 18
Rob
Thanks for the lead, Rob. Which model A/C unit are you installing in your Airstream?
I also found a few windowless A/C units while searching on the internet.
1) Fujitronic FA-9000 Windowless 9,000 BTU Portable Air Conditioner $340 to $401
2) Soleus KY32U 12,000 BTU BTU Portable Air Conditioner
Cooling Area: 450 sq.ft - With Dehumidifier Function, With Fan Function - With Remote Control - With Timer
3) Delonghi PAC-210 7,500 BTU BTU Portable Air Conditioner
Cooling Area: 250 sq.ft - With Dehumidifier Function, With Fan Function - With Timer $329.99
4) Kenwood KW85 8,500 BTU BTU Portable Air Conditioner
With Dehumidifier Function - With Remote Control - With Timer $399 to $600
5) Sunpentown WA-7500M 7,500 Btu Portable Air Conditioner
$285 to $435
6) Delonghi AIR Conditioner $976 - $1200
7) HAIER 7000BTU PORTABLE AC HPAC7M $380
8) Amcor ALW12000EH Air Conditioner
$429 - $450
9) Sharp CV-P09LX Portable AC
$400 - $499
WBCCI Region One
Old 07-01-2006, 10:01 AM   #13
firefly007
firefly007's Avatar
longwood , Florida
Thanks for the ideas, but been there. Most of the portable units use inside air to cool the condenser. In a Bambi there just is not enough room and they tend to be noisy. Moving heat and getting rid of it to outside air is difficult. Dometic builds a nice unit called a CoolCat but it requires that you cut a BIG hole in your trailer.
Old 07-01-2006, 04:15 PM   #14
acrane
acrane's Avatar
Profile:  1980 31' Excella II
Stonewall , Mississippi
Ac
I am new, our ac does not cool our 31' the way I think it should (or want to it, lol). You are talking about a windowless unit. Is that because the one on top of your trailers just don't cool sufficiently?
Alice
acrane is offline   Reply With Quote
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 03:14 AM
A/C removal Rob Furnaces, Heaters, Fireplaces & Air Conditioning 14 04-22-2003 07:53 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 06:08 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 05:16 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 08:52 PM
test
