Old 09-18-2015, 11:12 PM   #15
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Window AC
65 GT Man
I designed a window mount for my 66 TW and it works great. Mostly it rides in the bottom of the wardrobe closet. It only takes 10 minutes to install. I could not wait to get that ugly wart off the top of my Airstream.
For photos and lots of details I have a thread dated June 1, 2012 titled 5000 btu/hr AC powered by a 1,000 watt Genny.
I hope this helps.
Dan
Old 09-20-2015, 10:08 PM   #16
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Here are some photos of my window installation of a 5,000 btu/hr AC unit. As you can see, it only takes up about 1/3 of the window, so you can still see out and let natural light in. It is located in the middle bedroom/closet area of the Tradewind. Therefore, if you close off the front area and the rear bathroom, I don't care how hot it gets, the ac will cool this small 40 sq ft section, in the event a small child needs to take a nap in the middle of the day. Part of the key to the design is that the ac unit is mounted on the window frame at the cg (center of gravity) of the ac unit. Therefore no external support is needed.
90% of the time we don't need AC and the unit rides in the bottom of a cabinet.
If you want more information, tap on Touringdan, tap on statistics to find the threads I have started. Then tap on the 5,000 btu/hr AC powered by a 1,000 watt Genny thread.
Dan
ID:	248596   Click image for larger version
ID:	248598   Click image for larger version
Replacing Air Conditioner with Roof Window justgoclimb Windows, Doors, Locks & Vents 13 08-15-2015 10:54 AM
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
Old air conditioner removed... Steps for new installation Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-14-2011 03:25 AM
window air conditioner in cabinet? Smoky Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-04-2009 04:10 AM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
