Old 11-05-2018, 06:10 PM   #1
2018 25' International
Kennesaw , Georgia
Will then heat pump switch over to the furnace?
We have a 2018 25FB International Serenity. When the Dometic thermostat is set to HP (Heat Pump) mode will it automatically switch over to the Furnace mode when it's too cold outside for the heat pump to work?
wsrb is offline   Reply With Quote
Old 11-05-2018, 06:19 PM   #2
2015 28' International
Ofallon , Missouri
My Dometic thermostat does NOT automatically switch to furnace. HP and Furn are separate modes.
mpsgolf is offline   Reply With Quote
Old 11-05-2018, 07:06 PM   #3
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Mine does. If the heat pump runs for a certain amount of time and does not satisfy the thermostat the furnace comes on.
Old 11-05-2018, 07:21 PM   #4
OriginalMrT's Avatar
2017 27' International
Orland Park , Illinois
I think the mode needs to be set to auto for that to happen.
Mark
OriginalMrT is offline   Reply With Quote
Old 11-05-2018, 07:22 PM   #5
2017 23' International
hendersonville , North Carolina
Furnace kick in
The furnace in our 2017 23D kicks in if HP can't keep up. We experienced this last November in Columbus, Ohio. We got caught in a cold snap (20 degree nights for 5 nights). I now try to set thermostat to furnace ahead of time if it is going to be really cold.
uraljohn is offline   Reply With Quote
Old 11-05-2018, 07:28 PM   #6
2019 23' International
2019 Interstate Grand Tour Ext
California , Dunbar Drive San Pedro
Yeah! when you set to Hp and after running the heat pump it automatically switches over to the Furnace mode.
robertstaley is offline   Reply With Quote
Old 11-06-2018, 11:47 AM   #7
2017 27' Flying Cloud
Rockaway , New Jersey
wow never knew this! Great question.
I now will feel more comfortable using the HP, and campsites electric instead of my propane, when I leave the AS there for a period of time unattended.
Tomfeury is offline   Reply With Quote
Old 11-06-2018, 11:58 AM   #8
Mollysdad's Avatar
Mine did.
About 30 degrees. However, I never set up the programming. I can only assume the dealer put a program in or a miracle happened.
Old 11-06-2018, 12:26 PM   #9
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Don't feel ignorant. I had mine for 10 years before a tech at Airstream Service
informed me.
guskmg
Old 11-06-2018, 06:15 PM   #10
Fort Worth , Texas
Really? We have a 2017 FC and just returned from a camping trip to Utah. We had the HP running one night and it got down in the 30's. The HP seemed to run non-stop, but it did not switch over to the furnace.
Do you have to have Auto set for this to happen? I can't imaging setting it to HP and having it change automatically???
billrector is offline   Reply With Quote
Old 11-06-2018, 08:25 PM   #11
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
On my older Dometic 5-button CCC thermostat, auto mode is for fan control. The heat pump has a temperature sensor in the outside unit and the thermostat switches to furnace when it reaches 30 degrees. With the heat from the compressor, 30 degrees in the unit is probably several degrees above the ambient.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-07-2018, 12:36 AM   #12
Mollysdad's Avatar
I couldn't either, but it happened. If you look into the manual for the climate control unit, (CCC 2) it mentions a "auto changeover". I never did anything, but at around 30 degrees, the furnace kicked on.
I got up the next morning and felt warm air at my feet.
Nice feature.
Auto Change Over Heating: If the room temperature goes below the temperature set-point by 2 F / C, the available heat source will be cycled ON until the room temperature reaches the temperature set point at which time it will cycle OFF.
If more than one heat source is available on this zone, the priority for selecting the heat source will be heat pump (first), furnace (second), and heat strip (third).
F. Auxiliary Heat (Heat Pump Models Only)
Auxiliary heat operation will be activated when the measured temperature of the outdoor temperature sensor is less than 30 F (-1 C). If the system is equipped with a furnace, the control will select FURN heating mode for the auxiliary heat source. Auxiliary heat operation, once initiated, will have priority over a heat pump defrost cycle. Auxiliary heat operation will be de-activated and the heat pump operation will resume when the temperature of the outdoor temperature sensor is higher than 35 F (2 C).
Old 11-07-2018, 08:34 PM   #13
Kennesaw , Georgia
Reporting back as we’re in cold enough temps to try this out. Outside temp is 30F. The heat pump was working but instead of automatically switching over to furnace it froze up. So, I just switched the thermostat to furnace. Seems that answers my question for this 2018 25FB international serenity.
Old 11-09-2018, 10:19 AM   #14
ChuckZ's Avatar
1966 26' Overlander
2012 28' Flying Cloud
Waukesha , Wisconsin
Thanks for the thread WSRB. It's good information since we'll be picking up a 2012 FC 28 with a heat pump in 2 weeks. Never had one in our '66. It'll be great.
Chuck
ChuckZ is offline   Reply With Quote
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 10:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 08:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 03:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 05:23 PM
