Old 01-20-2011, 11:57 AM   #1
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek , California
Why heat to holding tanks?
I just gutted my 75 Tradewind. Omg! All the critter debris!!! While I was removing the furnace ducts I found 2 inch round ducts going into the belly. Why would I want my heat going into the holding tanks every time I use the furnace? I get it that I might need this in freezing weather, but the ducts are not operable. Always open.
When I start my rebuild, should I replace these or remove them? I don't plan on doing any camping in freezing weather. I'm in California and plan on camping here.
Breadbug is offline   Reply With Quote
Old 01-20-2011, 11:59 AM   #2
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
It was to keep the tanks from freezing, yes. But you certainly can put dampers on them if not needed - I.E. Extended freezing temps while on the road.
We have them too and they were a main mouse highway into and out of our trailer. Now, Kimber doesn't want that furnace run until the ducts are sanitized.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 01-20-2011, 12:04 PM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
If you ever sold the trailer and I was the buyer, I would not be very happy when I discovered them missing. It is standard on nearly all travel trailers to have some heat routed to the holding tanks. I can think of kinds of circumstances that could arise where the trailer could end up stuck in freezing temperatures with water in the tanks.
Ken
Old 01-20-2011, 12:39 PM   #4
Breadbug's Avatar
1969 31' Sovereign
1975 25' Tradewind
Ok, I hear ya. So, I have to figure our a clean nice way to duct them and have dampers on them. I am gonna clean and sanitize the main ducts. I don't want critters gettin back in. The belly is really clean but ya never know.
Any good ideas for where to get 2" dampers? Seen any clean nice engineering for them?
Old 01-20-2011, 12:44 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
::shrug:: not much air goes through the 2" ducts so you're not going to save much propane by closing them off. Just sayin'.
You might have better luck finding 4" dampers and setting everything up so that the dampers are before the reducer. 2" is an odd size.
Old 01-20-2011, 02:06 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
False sense of security
I can't believe they are all that effective; since they don't have a return duct for the air. Most tanks that I am aware of are in an enclosed space; so once you pressurize the space by blowing air into it, the air stops flowing along with the heat. It's like most things in life; the air will take the path of least resistance. If given the choice to flow thru a 2" duct with back pressure or a 4" register on the interior of the trailer it will flow out the register.
Old 01-20-2011, 02:12 PM   #7
Ag&Au's Avatar
If they are like the ones in my trailer, the hole is about a 4"x4" hole with a 2" diameter pipe inserted into it. That is plenty of room for the air to escape back into the trailer. Also, since the furnance and tanks are both near the fore/aft center of the trailer, the hoses are short with no restrictive vent on the end. Not to mention that all you need to do is keep the spave above 32F.
Ken
Old 01-20-2011, 04:03 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
TG Twinkie -- no-return is an issue if construction was watertight. Speaking of which ... would my old '59 VW's belly pan have prevented it from sinking in da lake? (no, I don't think so...) But I agree one would have to be staying at the 'stream to monitor this in really dicey conditions. It does get closer to the line when traveling; ie, no protection at all if you're not willing to run LP underway. Fyrzowt -- ready for your input!
I'm with Buttercup -- put dampers on them. You're not seeing much LP disappear even without dampers.
This becomes a resale issue -- like people who think they're saving something by putting in a dorm fridge (cuz that's their lifestyle) rather than a real RV fridge. It's nice not to have to modify your future travels & dreams because of overlooking this tank heat feature. See http://www.airforums.com/forums/f161...tml#post936582
5 meter Langford Nahanni
Old 01-21-2011, 10:23 PM   #9
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
OK Bob, now you put me on the spot...
My only comment would be to echo what has already been said. You really need to consider the next owner as well as your own needs. Yeah, chances are that the next owner wouldn't check for tank heat ducting, but rather than pull it out, I would either leave it as designed or add dampers.
As to travelling with the fridge on or off, that's a fight for another thread. Been there, done that.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 01-22-2011, 12:18 AM   #10
Trex's Avatar
1981 20' International
Shasta Lake City , California
If you plan to move to Green Bay...keep them! If you plan to live in Califorina, I think you can lose them.
"Sometimes you eat the bear, and sometimes, well, he eats you." -the Stranger-
Come and see me at: http://www.airforums.com/forums/f185...-71804-60.html
Trex "Airstream Nomad"
Trex is offline   Reply With Quote
Old 01-22-2011, 07:16 AM   #11
RaleighAir's Avatar
1973 31' Sovereign
raleigh , North Carolina
So any ideas how to get heat in here when the furnace has been removed? PO removed mine and just has a catalytic heater now (PO said they just used a little ceramic heater in back). In redoing the rear bath/separation rot, I've removed the filthy and crushed ductwork back there. (i also removed the small "home" elec hot water heater PO had and want to replace with lp/elec, got a dorm fridge too that I want to remove/replace with lp/elec fridge, also no univolt - this thing had been set up to just plug in, not boondock).
Maybe redo the ductwork and just use a small fan to force warm interior air around the tanks? Would some sort of heat tape/mat work to warm holding tanks? Didn't want to go back in with a furnace but I guess I could. Just more time/money and I'm ready to get this thing on the road!
RaleighAir is offline   Reply With Quote
Old 01-22-2011, 09:46 AM   #12
Fyrzowt's Avatar
2000 25' Safari
Images: 8
One other thought regarding mice entering through the ducts.
Run the ducts into a mouseproof grill, or cover the ducting ends with mouseproof screen in the belly area. When thinking mouseproof, think VERY small openings!
AIR #15800
2000 Safari SS 25'
Old 01-22-2011, 10:54 AM   #13
c177tx's Avatar
2008 19' Bambi
Images: 20
When the temps are above freezing I will run a small electric heater or the heat pump and I have noticed that while not running the furnace and using another heat source: ie electric heater or the heat pump (so in those cases my tanks are not heated with the ducted air from the furnace) the floor is cold and makes the back of the trailer colder. When I use the furnace the back of the trailer stays warmer. The duct going back to the tanks both heat the tanks and the floor above them. just my observations from full timing in my little bambi.
c177tx is offline   Reply With Quote
Polished Aluminum Tanks NicheVintage Cleaning, Stripping & Polishing 12 07-05-2014 03:31 PM
75' Tradewind replace tanks? Breadbug Fresh Water Systems 7 03-06-2011 10:11 AM
'75 Tradewind replace tanks? Breadbug Fresh Water Systems 3 01-21-2011 11:53 AM
Heat Pumps Brianv512 Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-19-2011 05:15 PM
Need new LP heat source for short bursts of winter use pyrenees Winter Living 12 01-04-2011 08:41 PM
