Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 08-18-2004, 09:47 PM   #1
jgouras's Avatar
1966 24' Tradewind
snohomish , Washington
Question why does the heat duct connect to the black water tank
i have a delema. my cold air return ( according to my manual) on my 66 tradewind goes into the black water tank area. why is this? since it is pulling air from this area to the heater to be heated it does not keep the tank from freezing as i once thought.
help i am very perplexed
jon
jgouras is offline   Reply With Quote
Old 08-18-2004, 11:54 PM   #2
Creampuff
Creampuff's Avatar
2022 27' Flying Cloud
2016 25' International
Airstream - Other
Malibu , California
Images: 60
jon
Your confusion probably lies in the fact that the duct is for heat distribution , not return. It will supply warm air to the black tank to prevent freezing.
Mine has a flex hose that takes off just rear of the rear register. Return air is sucked in under the cabinetry.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 08-25-2004, 10:42 AM   #3
jgouras's Avatar
1966 24' Tradewind
my confusion is based in my manuals (original owners manual) lack of confusion, which clearly states that those are cold air returns, not heat ducts. any further assistance would be much appreciated.
thanks
jon
Old 08-25-2004, 10:49 AM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Errata sheet missing
Then your manual is wrong (it happens). There is a real simple test if your furnace fan currently works (LPG not needed for this test). Turn the furnace on and feel which way the air moves. I will bet you find air moving toward the black tank box.
Tom
Old 08-27-2004, 02:25 PM   #5
This thread is interesting. Can some one tell me if this is normal. When we fire up the furnace there is a considerable blast of heat that purs out the vent from the furnace compartment to the outdoors. We have a '78 Sovereign. The vent I am talking about is in the wall to the left of the furnace and goes directly out. the vent itself i next to the door. ?????????? D'Andrea
Kalakala Too is offline   Reply With Quote
Old 08-27-2004, 02:28 PM   #6
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
If you are referring to the chrome vent on the outside of the trailer, that is normal. This is the waste gasses form burning the propane. In a normal home it goes up the chimney. You do not want that air in the coach, it contains CO (carbon monoxide) and could kill you
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
Black Water Tank David Hall Waste Systems, Tanks & Totes 3 12-28-2003 07:24 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
