Old 02-22-2012, 01:39 PM   #1
1964 26' Overlander
Richmond , Virginia
Why are some AC shrouds facing the wrong way?
I would expect most AC shrouds to face with the sloping part in the wind, and the thickest part toward the rear, so that when you drive down the road, you get less wind resistance. However, I see them facing the other way all the time. Are there that many that are installed wrong, or is there a reason for this? (airplane wings have the thicker portion facing into the wind and tapers to the back)
robwok is offline   Reply With Quote
Old 02-22-2012, 02:16 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
They are installed wrong. The installer was a(n) [insert your own insult here]!
Not only does it present the blunt end aerodynamically, it exposes the condenser's fins to damage from anything that might come down the top of the trailer. Including hail, gravel, birds, etc...
And you're right, it does seem like there are a lot of them.
Vaughan
Old 02-22-2012, 02:56 PM   #3
1981 31' Excella II
Orlando , Florida
I have seen air scoops on the top of some trailers that look like air conditioners. I can't imagine anyone being so stupid as to install one backwards.
Perry
Old 02-22-2012, 02:58 PM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
The principle source of air resistance at trailering speed is form drag, caused by an uneven pressure distribution around the object. The shape with the lowest air drag (at least not near other surfaces) is the tear drop; the blunt leading edge and long tapered tail are typical. The tail is important as it helps reduce the formation of a low pressure zone to the rear.
How much practical effect this has on the roof of a trailer is a matter of debate; the airflow is hardly undisturbed by that point.
The shroud on our AC is pretty blunt at both ends.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Repairing holes in the interior RedAsh Upholstery, Blinds, Walls & Interior Finishes 8 05-16-2012 06:46 PM
The Airstream Scam Revealed MORA Off Topic Forum 46 03-04-2012 11:01 AM
Keeping the pipes from freezing and busting chrischarles Winterizing, Storage, Carports & Covers 8 02-23-2012 09:42 PM
How can you tell the brakes are...? AIR-Quarius Brakes & Brake Controllers 11 02-22-2012 07:20 AM
Popped rivet near the top door Hodum Ribs, Skins & Rivets 3 02-21-2012 09:53 PM
