Our 2014 31' Classic has Zone 1 as living room (where the thermostat is located) and Zone 2 is rear bedroom where there is a small temperature sensor.
We have a hybrid Magnum MSH-3012 inverter in our 2015 23D International Serenity with a single 13,500 BTU air conditioner. The Magnum can draw from our 300 amp-hour lithium battery to augment the single 2,000 watt Honda generator (we carry one for the 23D) starting the air conditioner as it cycles with the temperatures.
We carry the two 2,000 watt Honda generators set with the Classic. The pair can run either the 13,500 or the 15,000 BTU air conditioners one at a time. The 600 amp-hour lithium battery thru a Magnum MS-2812 inverter can run either air conditioner for over an hour.
