Old 07-30-2009, 02:58 PM   #1
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Which new AC models come with a drain pan?
I've still got my Armstrong and would like to get a new AC unit.
Which new units have come with a pan? I believe that standar and low profile Carrier units have a pan that you can modify by with a small brass fitting to provide a conneciton to the drain hose.
Are their other brands / models that have a pan as well?
If not, anybody know about how much a pan costs?
Ron
ronstory is offline   Reply With Quote
Old 07-30-2009, 05:02 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I installed a Carrier Low Profile on my 75 Trade Wind earlier this year. It came with all the parts needed to attach it to the drain tube that was on my old Armstrong.
Richard
Old 07-30-2009, 06:22 PM   #3
2008 16' Safari
Destrehan , Louisiana
None, they all use a drain tube.
dlb435 is offline   Reply With Quote
Old 07-31-2009, 04:50 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The Penguin also has a drain pan available. We went with Carrier also (yet to be installed).
Drain Pan for Dometic Penguin AC 961270 [961270] - $59.95 : ODMRV , Out-of-Doors Mart
Old 07-31-2009, 02:34 PM   #5
ronstory's Avatar
1975 23' Safari
Portland , Oregon
All--
Thanks f
Ron
Old 07-31-2009, 02:36 PM   #6
ronstory's Avatar
1975 23' Safari
Portland , Oregon
All--
Thanks for the replies. So with the dometic I'll need to factor in another $60 to get the pan. Does anyone know if they make a pan for the Coleman units? I'd really like to get a coleman PS (Power Saving) AC so i could run it on a single 2KW generator.
Ron
Old 07-31-2009, 02:38 PM   #7
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Ganglin--
One more question, did you get the LP or the standard Carrier? If it is standard, it did have a drain port in pan or will you need to add the brass fitting workaournd?
Ron
Penguin drain pan gasket markdoane Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-14-2006 09:36 AM
AC/Drain pan problem guy99 Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-27-2005 08:42 AM
Drain Valve Under Belly Pan wayner1239 Waste Systems, Tanks & Totes 3 12-28-2004 10:13 AM
Penguin Drain Pan- Where to buy? Joe Z Furnaces, Heaters, Fireplaces & Air Conditioning 10 08-17-2004 04:17 PM
Need photo of drain pan support Lexxy 1966 - 1968 Safari 3 05-04-2003 01:53 PM
