Old 07-10-2015, 04:42 PM   #1
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
Which is which?
I am sure this has been asked before but I can't find the thread. I have a 2015 27' FB with 2 AC units. I am currently at a park with only 30amp connections. It's 98 degrees outside and I would like to use the 15000 btu unit since I am restricted to using only one unit. Does anyone know which is which? I would presume it's the one in zone 2, closer to the rear of the trailer, close to refrigerator and galley but I am not sure. Thanks for your help.
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 07-10-2015, 05:59 PM   #2
SteveH's Avatar
Common Sense , Texas
It's usually the one in the living area, and if you have a FB, it should be the one in the rear. Also the 15,000 btu unit has additional cooling air flow holes in the schrowd, or top cover.
Regards,
Steve
Old 07-10-2015, 06:31 PM   #3
Hogfan's Avatar
Dallas , Texas
We have the same and have been told that the 15,000 BTU unit is over the living room.
Hogfan is offline   Reply With Quote
Old 07-10-2015, 07:04 PM   #4
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Same unit here and mine is in the rear over the living area and is controlled with Zone 2 on the bedroom-based thermostat. Joe
jayseejay is offline   Reply With Quote
Old 07-11-2015, 09:25 AM   #5
Montgomery , Texas
Thanks all. While we are on the subject, has anyone noticed significantly reduced airflow from the zone 1 unit in the bedroom area? I have noticed that when running zone 1 only that I actually have more air flow from the air ducts over the dinette than in the bedroom. Also, when connected to a 30 amp connection is it ok to run the fan only on one unit while running the other in the full cooling position?
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 08:37 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
