Old 07-12-2009, 09:58 AM   #1
airfoil's Avatar
1972 Argosy 20
Maryville , Tennessee
Where to install AC on '72 Argosy 20
Hello,
I have purchased a Coleman AC unit and I will install myself. Can anyone tell me where the unit should be mounted? I have see several posts and the best I have come up with was Andy from Inland RV advising that on a 22' Argosy, the opening should be made 71" aft of the 0 bow.
Is the correct for a '72 Argosy 20? Was the model Argosy pre-wired?
John
John
Count all your blessings, remember your dreams. jb
airfoil is offline   Reply With Quote
Old 07-12-2009, 10:32 AM   #2
Originally Posted by airfoil View Post
Hello,
John
The Coleman AC's required a "drain pan."
Without it, water will run down the sides of your Argosy.
Old 07-12-2009, 10:40 AM   #3
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
When Andy speaks......People listen!!!
62bam is offline   Reply With Quote
Old 07-12-2009, 11:57 AM   #4
airfoil's Avatar
1972 Argosy 20
Thanks Andy,
What kind of drain pan will I need? Do you know of an example photo?
Also, Am I correct that the ac should be 71" from bow 0 and should I expect to find a wire there?
John
Old 07-12-2009, 01:10 PM   #5
Thanks Andy,
The Coleman drain pan has not been available from Airstream for a number of years.
I can answer your second question, tomorrow, when I am at my office.
Old 07-13-2009, 10:31 AM   #6
airfoil's Avatar
1972 Argosy 20
Thanks Andy,
I look forward to your reply to my second question.
With regard to my first question about a Coleman drain pan. What are my options?
John
John
Old 07-13-2009, 10:52 AM   #7
airfoil's Avatar
1972 Argosy 20
Okay...now i get it. The drain pan is inside the unit under the evaporator. I read this very good article bryantrv.com/roofacleaks.html by Christopher D. Bryant. The article has very good illustrations.
Thanks again,
John
John
Old 07-13-2009, 10:57 AM   #8
Thanks Andy,
John
John.
The records are not that clear on a 20 foot Argosy.
I would guess that the dimension would be a few inches less than the 71.
Perhaps about 64 to 65 inches.
Someone answered your pan question.
Old 07-13-2009, 05:09 PM   #9
airfoil's Avatar
1972 Argosy 20
Thank you Inland Andy,
That is about what I guessed looking at the little dot in the owners manual. It falls between to bows which makes sense. The only concern that I have now is the distance between the two vents. I wonder if the ac will fit. I guess I will measure.
John
John
Install TV in bedroom hfc7713 Electrical - Systems, Generators, Batteries & Solar 0 06-24-2009 09:12 PM
How NOT to install. Inland RV Center, In Furnaces, Heaters, Fireplaces & Air Conditioning 12 05-21-2009 08:43 PM
New AC install advice sound-silver Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-08-2007 11:56 AM
Should I install AC myself? Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-22-2004 11:26 AM
inverter install wb13798 Mechanics Corner - Engines, Transmission & More... 10 01-24-2004 02:49 PM
