Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-01-2018, 11:29 AM   #1
billrector's Avatar
2017 27' Flying Cloud
Fort Worth , Texas
Where is the condensate drain in AC pan on roof
I am doing some maintenance on my 2017 FC FB 27'. I have the cover off of both AC units to clean and inspect them. I'm looking for the drain hole for the pan as I have one unit that is not draining down to the wheel well as it should. I am unable to find where this condensation tube goes into the AC unit itself and have not been able to find a picture on the internet. Any help would be appreciated.
BTW...I've tried to use both compressed air and weedwacker cord with no luck from the bottom.
billrector is offline   Reply With Quote
Old 09-07-2018, 06:45 PM   #2
Cispook's Avatar
Greer , South Carolina
Following - anyone ever answer you
Cispook is offline   Reply With Quote
Old 09-07-2018, 07:43 PM   #3
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
Oye....best of luck.
14 Serenity 28'
15 Grand Cherokee EcoD
#5261
westernjeep401 is offline   Reply With Quote
Old 09-07-2018, 08:04 PM   #4
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
I was able to inspect mine inside by pulling the intake filter covers off.
Rick
2017 27 Tommy Bahama
2020 2500 GMC Duramax
rperrym is offline   Reply With Quote
Old 09-07-2018, 10:06 PM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Drain cups are mounted to the bottom of the AC unit on either side close to the front. The cups hav a barbed fitting that the drain hose connects to. The drain hose is routed through the foam base gasket between the roof and AC unit. Best way to see/ inspect the lines is to drop the inside air distribution box by removing the 8 screws. Not sure if any of this applies to a ducted AC system.
See photos
ID:	321806   Click image for larger version
ID:	321808   Click image for larger version
Condensate Drain Question khollister Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-15-2016 05:05 AM
A/C condensate drain tube? Gearheart All Argosy Trailers 3 07-02-2014 10:29 AM
replacing condensate drain tubing wmarsha Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-28-2009 06:39 PM
Condensate Drain mkeith54 All Argosy Trailers 3 08-18-2003 02:01 PM
'70's condensate drain? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 12 04-16-2003 07:05 PM
