Old 05-22-2008, 02:09 PM   #1
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
Question where does this duct go??
We are putting the gas lines in and this flexible hose is hanging down underneath the unit. The belly pan is off and we can't figure out where this duct hose is supposed to go.
Can someone advise us, please?
wannaroam is offline   Reply With Quote
Old 05-22-2008, 02:14 PM   #2
cameront120's Avatar
1972 25' Tradewind
Is it a fresh air intake?
North Vancouver, BC
Old 05-22-2008, 02:18 PM   #3
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Attachment 60848
It is probably the heat for the black and grey waste tanks!
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 05-22-2008, 02:24 PM   #4
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Paul
Sorry, I had two 1978 a 31' and 25' and looking at your sketch it appears to be of a rear bath model. The heat duct for the tanks came off the duct along the wall at the rear, in the closet just forward of the shower.
I have no clue what that duct would be for.
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
Old 05-22-2008, 02:27 PM   #5
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
our 1976
On our 1976 Overlander we have flexible ducts (3 total) that heat the area around the fresh, grey and black tanks.
My guess is your forward flex duct is to warm your fresh tank area.
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 05-22-2008, 02:33 PM   #6
wannaroam's Avatar
Images: 36
We actually have the center bath unit. This hose in directly under the furnace.
Old 05-22-2008, 02:36 PM   #7
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Our water tank in in the center of our trailer, and we have a flex hose that runs directly off of the main vent that heats the fresh tank area.
Hensley Hitch
Old 05-22-2008, 03:35 PM   #8
wannaroam's Avatar
Images: 36
Where do you put it exactly? Does it just lay above the belly pan or is it supposed to attach somewhere?
Old 05-22-2008, 04:06 PM   #9
Excella CM's Avatar
Venice , California
As noted before, it's the fresh air intake into the furnace for the heated cabin air. The combustion intake is next to the exhaust on the side of the trailer. And yes, it just hangs there.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-23-2008, 01:01 AM   #10
Mexray's Avatar
1978 28' Ambassador
Morada , California
Could it be that that duct supplies some heat under the floor, just forward of the fresh water tank that's mounted over the axles?
It's probably just blowing enough warm air into that cavity between the floor and belly panels to keep the temp above freezing....
Old 05-23-2008, 06:15 AM   #11
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
I think ducts go south for the winter...
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 05-23-2008, 08:24 AM   #12
Excella CM's Avatar
Venice , California
Ooops!
Yes, the ducts go south where it's warmer. That hose take heated air into the belly pan to keep pricey things from freezing. Brain f---, sorry. A lesser man would be embarassed.
Old 10-28-2013, 07:45 AM   #13
KYAirstream's Avatar
Northeastern , Kentucky
Originally Posted by wannaroam View Post
We are putting the gas lines in and this flexible hose is hanging down underneath the unit. The belly pan is off and we can't figure out where this duct hose is supposed to go. Can someone advise us, please?
Just curious what you ended up doing with this duct? Mine has the same configuration in the service manual, but I can't see what relevance this duct has when the other two ducts are so near the tanks .
KYAirstream is offline   Reply With Quote
Questioning a Duct Stone Ridge Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-09-2008 08:20 PM
disconnected duct boondockdad Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2007 05:26 PM
Duct work mark silberl Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-30-2007 02:11 PM
Duct to nowhere walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-17-2004 07:16 PM
Duct Tape Popup fireflyinva Off Topic Forum 10 12-05-2004 05:54 AM
