Old 10-06-2014, 12:56 PM   #1
1974 29' Ambassador
Dillonvale , Ohio
What's the cubic feet of airspace in the '74 Airstream Ambassador ?
I want to put in a electric heater in my 74 (29') Ambassador. Could you tell me the cubic feet of air space so I get the right size electric heater! I want to use 220V. Thanks , Jeff
jcdflint is offline   Reply With Quote
Old 10-06-2014, 01:15 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It doesn't have to be exact; just multiply length times width times height, and call it good enough. Deducting for the space occupied by furniture and such is more effort than it's worth.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-06-2014, 01:32 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Why do you want to use 240 volts?
Your coach is not wired for 240 volts.
How do you plan on powering the space heater?
Our coach is 26'. We use two 1,500 watt electric space heaters when power is available and temps get down to zero. One heater is plenty when temps are around freezing.
The specs on these heaters are iffy at best. Because it depends on how well insulated the space is.
Old 10-06-2014, 02:46 PM   #4
1974 29' Ambassador
Dillonvale , Ohio
Thanks my Airsteam is set up on my farm. I use it for hunting friends. I already have 220 wired into it for electric stove I put in. The 220 heaters have higher watts and BTUs then the reg.110 (1,500 watts) I'm not a fan of using prop.
Old 10-06-2014, 03:18 PM   #5
1981 31' Excella II
New Market , Alabama
Well 20,000 BTU's should be plenty. That is about what the furnace puts out. The heater in the AC is about 5000 BTU's and it keeps it warn down to about 30.
Perry
Tire Size for 63 Ambassador 28 feet? Rivetrivet Tires 2 09-07-2014 12:21 PM
Dometic RM 75 cubic feet Tony S Refrigerators 6 02-24-2014 08:41 AM
5 Cubic Ft Fridge Performance in 23 models KJRitchie Refrigerators 10 07-24-2013 10:58 AM
1972 Airstream International Land Yacht Ambassador :: 1972 Airstream Ambassador airpatton Airstream Registry Discussions 0 03-22-2012 12:01 PM
technical info on 67 ambassador - length 28 feet bishopbonner Member Introductions 3 05-28-2008 07:12 PM
